No crank, no start issue, water
Hey folks, I'm dealing with storm prep and having trouble finding ideas on this, so I thought I'd hit up the brain trust. ;) Ideas and links to prior discussions are welcomed (appreciate it!).
I have a 2004 4R that leaked through the sunroof over the past week of rain ahead of hurricane Milton (inbound, prep is my main concern right now). I'm not sure whether the water overflowed the gutter only, or the drains as well. I found the mechanism fairly rusted and lots of rust in the gutter that seemed to be blocking the drain. The headliner was damp and the floor was soaked (about an inch of standing water in the drivers side footwell, whole floor area is wet).
OK, so the real issue -- the vehicle won't turn over. The battery is good. The starter relay clicks when the ignition is turned. I also swapped the starter relay with the fog relay, no change. There is no sound from the starter or starter solenoid. I got the vehicle towed home and into the garage and vacuumed out all the water from the sunroof gutter and floor. It's got fans on it now and shouldn't get soaked during the storm (provided the garage doesn't break, and that would change my priorities quickly).
Anyway, I'm leaning toward a failed starter or water intruding on something I'm not aware of. Given the scenario, is there anything I should check or test prior to replacing the starter?
Thanks in advance, and stay safe to the storm impacted ppl out there.
I'll start with removing both pos & neg connections @ battery and do a good clean to ensure good contact upon reinstall. Next turn on head lights and try cranking engine. If lights dim and starter relay clicks , your battery is low on charge or not as good as you had thought previously and do not have the reserve to turn engine over.
I did try this prior to towing the vehicle. There was no dimming of the headlights, which is what made me wonder whether something important suffered water intrusion.
I also checked all the internal fuses and all the external fuses that looked likely to contribute (it was raining, anything related to starting, ignition, ECU I checked).
I attempted jumper cables, but there was no indication of low voltage/battery issues. It didn't even spark when I connected the cables.
Current status is battery disconnected, tested and charged with my charger. It's sitting at 12.8v.
V8 or V6?
When you say you checked the fuses, how was that done, just visually or did you do a continuity test with a multimeter?
make sure that battery is holding. check the ecm fuses some of them get corrosion and loose connection. had a no start issue when i put a new engine in, even had someone come out and said ECU was messed up. my boy happen to come by wiggled a couple fuses and boom she started right up. hopefully its something as simple. were you having start issues at all before??
V8 or V6?
Good point, visually mostly. I did some swapping of like fuses to verify the critical ones were really good. I’ll go back through them with a meter now.
Good point, thanks. While I’m verifying them all for continuity I’ll wipe the contacts with sand paper, just to make sure. Will have an update by tomorrow.
I still would like to know which engine you have, V6 or V8, it makes a big difference when accessing, troubleshooting and working on the starter?
Apologies, it’s the v6. Doesn’t look terrible to swap if that’s the most likely culprit. I’m worried something got wet though. I can’t find any indication of what yet, just was a really wet truck yesterday.
It's good you have the V6 with easier access to the starter.
Have you loosen the cables to the starter and cleaned and retightened them, if not might be a good idea to do so?
Not yet, adding it to the list for today. I want to let it continue to dry for another day before attempting to start. It's still damp at this point, but much better than it was. So today I will:
Check continuity on all fuses, sand contacts, reinsert. -- DONE. I found a burnt 20A fuse in the PWR Outlet spot on the internal panel (should be a 15A, replaced it). Otherwise no issues.
Sand battery posts and cables. -- DONE. All shiny clean, battery is holding charge. I ran my inverter and shop fan off it for about 10 mins and it dropped .2V, which seems about right. My charger still says it's good, and it's charging back up now.
Clean/sand starter cables, verify tight connections. -- Likely tomorrow. Need to put the truck front on jack stands for this and I want to test the front sunroof drains first.
Once the storm passes (late tomorrow or Friday AM) I'll reconnect the battery and try to start it.
Sorry for the slow update, I had to leave town for a week for work. Today I checked the starter connections and that looks to be fine as well. I'm waiting for some help so I can check for voltage at the solenoid. I hooked the battery back up, verified it again with my charger/tester, and the symptoms haven't changed -- still no crank, no click. I can hear the hydroboost pump for the brakes run for about 15 secs the first time I turn the ignition on.
I've been looking to prove out whether this is the starter, ignition switch, or the ECU. From what I've read the ECU provides power to the solenoid via the relay, and in a bad ECU situation I should be able to put 12v on one of the relay connections to cause the starter to engage and turn over (which would prove it's good). But I haven't been able to find a diagram for how to do that with this truck. Has anyone seen or done that? If you can confirm I'm wrong with this approach, I'll take that too. :)
Thanks!
Thanks!
Some things to try.
1. Try and whack the starter a few times with a hammer - kind of gently but firmly. If it fires up, replace the starter.
2. Check DC Voltage on the small control wire at the starter while cranking the starter. If you don't see 12V, problem is on the control side upstream. Make sure that wire is well connected to the starter. Make sure you have 12V on the big wire terminal even without cranking. Make sure that wire is well connected to the starter.
3. Bypass all upstream controls by running 12v to the control wire terminal at the starter. This should close the solenoid and you should probably here it click if it is good. If it cranks, problem is upstream. If it doesn't crank and you think the solenoid is closing, check voltage drop from positive battery terminal to big wire terminal on the starter while trying to crank. Should see less than 0.5 drop. If more, check connection at battery or perhaps wire is internally damaged. If no excessive voltage drop, replace the starter.
I appreciate it Buckaroo. #1 I've tried already with no result. #2 and 3 are queued up for tomorrow when I'll have a helper. This should prove out whether the starter is good. If it is, then I need to figure out whether the ignition switch or ECM is bad. If nobody posts one I'll do more searching today on the pinout for the starter relay socket. Low voltage there seems to be indicator of a failed ECM, no voltage there seems to indicate a bad ignition switch or possibly the transmission lockout.
The transmission interlock circuit is always the thing I check first. Sometimes, it'll start in neutral ("N") or fiddling with the transmission selector. With the parking brake on and wheels chocked, of course.
From what I've read, the immobilizer will allow cranking, but the vehicle won't start so I don't think that's it (still nothing at the starter). I have tried two different keys as well.
Today I swapped batteries with my 5th gen 4R (known good) and was able to start the 5th gen with this battery, same behavior on the 4th gen with the known good battery, so swapped back. I noticed more voltage drop than I think makes sense when trying to start though. Both batteries would drop to around 12.2v with the ignition turned to engage the starter, with no action at the starter.
I checked for voltage at the control wire on the starter and get nothing there, so it seems like the starter isn't being told to start. I need to put 12v on that and see whether the starter motor goes.
Just in case I have two marginal batteries, I also replaced the battery with a new AGM. It's charging up to full now, but I don't expect that to impact this issue.
Since the starter control will be tough to get it, I think I'll tackle the relay next and apply 12v to it via that. Ideas/feedback welcome! Thanks everybody.
Yes, put 12V to the starter signal terminal and verify it cranks. Then you can focus on the ignition switch and downstream wiring to the starter.
Starter relay location/possibly helpful video.
https://youtu.be/v594j6Bp21s?si=8Ag8dCzkTrP9CK77
AuSeeker, you're a rock star. I missed this and it's exactly what I was looking for. I followed along and verified my starter is good by shorting the two relay pins closest to the driver's side fender. I checked for power at the inside 7.5a fuse and found 13v there, so ignition switch seems good.
Now for the last pin on the relay -- this is my issue I think. I checked voltage between the ground pin and that pin (so the two pins furthest from the drivers fender) while the ignition was turned to crank the starter, and found 6.5v. Second oddity, is that 6.5v stays there after the ignition switch is released, which I wouldn't expect. I think I should see 12v here -- can anyone confirm?
So at this point I'm looking for a wiring diagram showing how power gets here. From what is described here, that voltage issue could be a bad transmission interlock (N versus P makes no difference to the problem) or a bad ECU. I'd expect bad interlock to provide 0v. I've seen at least one post in my digging where a failed ECU showed low voltage on these pins, but I'm only guessing at this point that 12v is what I should see.
Thoughts and ideas welcome, and thanks again to AuSeeker for the video link.
PRWhite
