Florida Frame Swap
BPmtn
Hello All,
Tried to find existing threads but didn't see any mentions aside from El Creador in Miami. I've reached out to them already.
I'm looking for someone to do the full frame swap on my 06 V8 while also replacing several other parts. I would go anywhere in the SE USA for this if I can find the right private mechanic or shop.
Any tips are appreciated, thanks!
Hello All,
I don't know of anyone to recommend...but just wanted to clarify, do you have a replacement frame already or are you looking for whoever does the job to provide a replacement frame?
Either. I've seen some mentions on places to source a frame but appreciate any suggestions.
Thanks!
The 2016 frame is "basically" the same? In what way is it different? How long did it take you and do you have your own garage?
Seriously.
The 2016 frame is the same??
[MENTION=798395]VortepJ[/MENTION] would have to answer this question since he was the one that posted that was the frame he used for his 2005 frame swap, but he hasn't been back on the forum since he posted that on 10-09-25.
Hopely he stop by and give us an answer.
Hey everyone! Sorry, life has been busy.
I'm hoping to do a build writeup once I'm verified to go over everything I did to my 05 (it's still a work in progress).
But yes, the 4th and 5th gen frames are extremely close (at least the two I had). The main differences that I could see are;
Front bash bar is different but the mounts are the same so you can use a 4th gen.
The bar under the radiator is slightly different, but I think all the mounting locations are the same.
The brake line brackets are in slightly different places, but a little careful bending got it lined up for me. I wish I had asked the junkyard to save the 5th gen lines, but I didn't think of it.
The big one for me was the engine and transmission mounts were all different, I'm not sure if it's a 4th/5th gen difference or v8/v6 difference, I'm guessing it's the former, but can't say for sure. Anyway I welded some new motor mount brackets and modified the old trans mount and it's been perfect for over a year now.
There is a post somewhere about suspension differences, it's basically just the hole for the rear shocks is smaller on the 4th gen. I ended up with a set of lightly used 5th gen shocks that I used, but you would probably have to get at least 5th gen bushings to make your shocks fit.
The body mounts, all the rear axle mounts, trailer hitch, steering rack, front differential all bolted up the exact way they came out.
Hope this helps.
I think I quoted the wrong post, my answer to your first question is in this forum.
I have a three car garage with no lift, I think it took me 3 weeks of nights and Saturdays to get it done. It's hard to say for sure there were a lot of other projects mixed in to the larger project and I rust sealed basically every part that I put back, so that took awhile.
I think a build writeup on a 4th gen frame to 5th gen frame swap has the makings of a legendary thread. We're at the point in the life of the 4th gens that some of these are going to junkyards just for frame rot.... even if the mechanics/body are fine
EDIT: Are you telling me that in this post here, you have an 05 4runner, with a 21 Tacoma front clip, on a 2016 4runner frame?? https://www.toyota-4runner.org/3898926-post23790.html
Fabbing motor mounts is not exactly turnkey. Agreed on legendary status.
I wonder how hard it would be to just do a SBC and tranny swap at that point..
erinobr2000
