FMULINO's **Build Thread**
fmulino
I've seen lots of this build threads around and I am very axcited about starting one... Hope you guys like it and that I can help others build some nice 4runners
This are the first pictures that were taken when the truck arrived at the dealership:
My First Mod "Dealership Installed Revtek 3" Lift Kit:
This was the first mod I did to the truck, actually I drove it off the lot with the lift kit already installed.
This was when they were just finishing up the install:
The day I drove it off the Lot Decmber 14th 2013
6,000K HID Conversion
This was my second mod
Before changing to HID:
During the works:
And Done:
I know this question might come up here so I'll give the information just now. I used H11 bulbs for both Low Beams and Fog Lights. I know the Manual says H16 for the Fog Lights but they aren't, they are H11s
New Tires & Tint
The last mods I kinda got them all together, My Tires, Tint & Remote Starter.
This is the end result of all the mods combined
Pictures were taken during christmas in Canmore Alberta
This was back at the garage just fixing one of the HIDs that had a loose connection.
Nice looking truck, man. I like this version of red over the past maroonish reds on the previous years.
During the works:
And Done:
Looks great, what brand conversion kit did you use?
Awesome rig brother! Really has me wishing I waited for the redesign. Lift and tires make a huge difference and really makes that front end look mean. If Toyota bombs the redesign for the 15 Tacoma I may have to think about trading.
Thanks!!
Thanks I appreciate the comments, I'm doing some research to see what will my next mod be. I'm thinking maybe Change all the interior lighting to white LEDs
Do it!! One of the easiest and cheapest mods that makes a helluva difference. The only ones that gave me problems were the front map lights. ended up using a small twist tie to wrap around the light and yank out.
LOL - I had the same problem (in my Tundra).
Solution:
Place small strips of the foam-y 3M double-sided tape on both surfaces of needle-nose pliers. Provides some adhesion/friction and a bit of cushion
Pics of the 30" LED Light Bar Behind the Grill
Hey man please send some pics when you get the LED bar installed behind the grill, I'd like to see how it looks. I've been doing some research on that and I found a web site that selld the LED bars with smoked lenses so when you install them behind the grill is hard to tell they are there and I like that. But I'm not sure if that will affect the brightness of the light
Sure thing. I have to find someone that will make a custom mount to hold it up. Currently the grill is 6 inches tall and it is 5 inches above the actual bumper. I need to find someone that will come up with some sort of mounting brackets first.
This is how I'm planning my LED bars to go
Of course in behind the grill, I haven't actually measured the openings to see what I can fit in there but I was thinking maybe 2 10" LED Light Bars. And I want the ones with the smoked lenses.
erinobr2000
