fog lights wont turn off....??
GX4SEVEND
So I installed the hella micro de less than a week ago using the factory wiring and changed out the turn signal stalk to make it as factory as possible. Today, I couldn't get the lights to turn off regardless of the car running or not. Had to pull the relay out to get them to turn off.
Any ideas what is wrong? Anyone dealt with this before?
Waiting for my set to arrive today. I don't have much experience but when something unexpected happens I go back through and recheck what I've done and usually I've just made a small error, such as a lose conection. Good luck. Sorry I could be much help.
The first component I would check would be the relay. It sounds like it is latched closed (stuck on). Do you have another relay you can try? Good luck!
2001ATL
