Fog lights
losso
Can someone help me I am trying to replace my fog lights on my 2001 4Runner I am looking for an alternative from stocks. Thx for help in advance
I’m interest too. Put OEM lights on and within a year one of the lenses cracked. I can’t find replacement lenses.
My wiring is so corroded that I need to either chop the pigtails and splice them into the OEM lights or replace the pigtails. Problem is that I have never been able to determine what 'plug' it is. Lots of searching and no luck. I haven't had any issues with the housings themselves.
I do have a small lightbar mounted on the front grill directly connected to the battery with a two-way switch. Not a bad way to go but Ideally you could have the bar + your fogs.
I had a broken lens on one of my stock ones a couple months ago and just replaced them with Hella Micro DE projection lamps. Had to do a little fab work to make a plate that allowed the universal brackets to mate up with the stock brackets but the placement was pretty good really. Here's how they look (sorry not the greatest pic but you get the idea).
[MENTION=67043]losso[/MENTION] I've got a used set of these that I'd give to you for shipping. PM me if you're interested and I can send pics. They are in good condition. I'd recommend doing this Fog Light Frustration if you go new.
Cheers
Have you got any pictures of the plate that you made to mount the Hellas? I managed to pick up a set of OEM fog lamps, brackets and relay for next to nothing, but the drivers side lamp glass is busted. I'm thinking of using Hellas, but I'd like to see what I'm getting into.
Sorry took me a bit to remember to snap some pics when it wasn't raining. I just used some metal sheet that I had laying around to make a plate that bolted to the stock fog light bracket then bolted the bracket that came with the hella light to that plate. As you can see it lines up pretty well.
delislerebecca
