Fog lights
losso
Does anyone know if it is possible to add another set of fog lights to the existing wire harness? Or do I have to run a separate one. Thank you for your help in advance
Would depend on current draw
160 watts divide by 12 . Is 13.3 amps a piece. 26.6 amps for 2. Almost 30 Amps. Your going to need a separate circuit.
However you can tie the switch to both relays just have to put another relay and circuit in to feed those lights.
what he says is what it is...another circuit...a relay...and your stock switch becomes nothing more than a on/off switch for new system triggering a new relay
Ambrose67
