Font component speaker install
Ruthven13
Has anyone here installed a three way component system in the front of their 4th gen? I have a JL Xr653 from a previous truck that I would like to install but not sure of a way to do a clean install. It consists of a 6.5", 4.5", and 1" tweeter for each side. Been looking around and have not found anything. Can't really spend any moer money on a different setup which is why I want to use wat I already have. Also, is there a diagram of what the back of the factory JBL nav unit looks like with labels for what each input/output does? My radio reception went to hell after installing a Kenwood DNX693S. I am sure with the knowledge base here that this has happened before. I would greatly appreciate and advice and apologize for my excessive babbling on this post. Thanks in advance!
That should work, you will just have to figure out what to do with the 4.5"ers
You can get adapters to mount the 6.5's in the 6x9 slots so I imagine you could make your own adapters to mount both there...
Yes its possible but you'd have to drill holes.What/where are you using for a backup cam
Sent from my XT1575 using Tapatalk
This. I made my own from some cheap cutting boards with a jigsaw, both for the 6.5's and 1" tweeters. You'll be able to see the cutting board material by the tweeters from the interior so don't use a green cutting board like I did :)
I've only got a wiring diagram for a non-nav unit but some of the stuff may be the same. To get your radio reception working again make sure you have supplied power to the antenna amplifier, e.g. from the accessory line.
At the moment I do not have the funds so I do not have a backup cam yet. Thank to y'all for the replies. I think I got the antenna power wire hooked up, just need to go back through the wiring mess to make sure it is the right one. I was hoping that both the 4.5" and the 6.5' components would fit in the stock opening, and am prepared to make adapters to do so. I was just wondering if anyone had done this and if they have pics...
So you're fitting 4.5 in stock tweeter location and 6.5 in stock speaker location?
How are you connecting amplifier in this configuration
Nope. Normal size tweeter in the upper factory opening. Was wondering what to do with the other two speakers on each side. Amp is a Zapco 360 4 channel. The speakers came with the needed crossovers. Just trying to make do with what I already have...
tuṣṭāva
