Found the howling noise...
sawguy
OK, I found the howling noise I originally thought was tire noise. It turns out to be the driver side wheel bearing. I'm looking for a tutorial on replacement (basically removal and replace) since I'll have someone else press the bearings on and off. Can't really find a very precise answer to removal. Is there a step by step on here? Do I have to remove the ball joints, etc? Thanks in advance. Also do I need to use oem parts?
OEM parts is he best bet.
If you're having someone else press the bearings in, take the spindle off and bring it in.
Take the 4 bolts holding the LBJ on off. They're 14mm. Take the caliper off, as well as the 12mm bolt holding the line to the spindle. Take the UBJ off and the spindle will come out, once you get the CV off.
pax at 4
