fox or new bilstein coilover options I need to clarify before I pull the trigger?
OK so not to start a pis sing war here but the comments about the lower bearings failing every 25k miles. Has anyone actually have that experience or is it that whit buffalo that exists in people's egos in this forum. So to get back on track here what do the factory shock use? Meaning if they haven't failed yet I am not worried about that.
I'm on my 3rd or 4th set at 80k miles. Stock shocks have a fixed upper mount and a bushing at the lower mount.
I'm hoping I'll have a little better luck with mine. At least they are rebuild-able.
Keep them lubed and away from road salt to last longer. The bearings are cheap COM10T (I get them from summit racing), and they are easy to change out, just kind of a PITA to pull the coilovers out.
what are you lubing the top & bottom bearings with? ICON says "no lubrication required", naturally. :rolleyes: they are supposed to be Teflon-lined. then again, the knock against ICON's UCAs used to be that the uniball was Teflon-lined COM10T—before they upgraded them to stainless steel.
anything else you've been doing to protect your ICON gear? i wish i'd installed a set of rubber shock boots on my rears when i put them in. i have the shin guards, but still... oh well, i don't feel like fussing with them now. maybe come spring/summer next year.
So far, they seem to last a lot longer using lithium grease to lube regularly. Top bearings last quite a bit longer than lowers, but I just replace them both at the same time.
I killed 1 set of rear shocks in like 10k miles because I didn't have any guards. I got Icon's guards for the second set, but they still got pitted above where the guard protects. I now have some generic shock boots I got off Amazon on my 3rd set.
maybe the "solution" is to source a stainless, PTFE-lined spherical bearing and replace with those next time. :confused: can't hurt, or be too much more expensive considering how often you've swapped them.
i have some minor pitting on the rear shock rods, but doubt it's anything a little elbow grease and a grey ScotchBrite can't remedy. good call on the shock boots. i wish i'd had my thinking cap on more squarely when i was putting my parts list together; didn't occur to me until i had it all apart and was staring at the delta between the shin guard and the bottom of the shock body.
I've got 2.0 rears. Stainless might help, especially in an area with road salt, but just the location of the bottom bearing pretty much guarantees it going to be constantly covered in crap.
COM10-ET are the stainless version and should work. Can't find them for sale anywhere, and the mfg mentions these are not normally stocked, so don't know the price...
Again, I'm aware. But this forum is flooded with people who buy ICON Because it's 'better'
i think it's more fair to say that more guys here have ICON suspensions because, since it was first introduced, there's been more 5Gs here on T4R.org than other forums and ICON was the first premium aftermarket suspension available. then Overland Warehouse went out of business, so the Radflo enthusiasm dimmed a bit. then, only relatively recently, King and Fox started to show the 5G some love, so you're starting to see more of those brands represented too. hence, the increasing frequency of the "digressive -vs- progressive" debate. my 2¢ anyway.
I also replace those spherical COM-10T bearings annually. They do fail and develop slop/make noise. I bought my last replacements from shockseals.com. They're cheap. The biggest PITA is the spiral retainer Icon uses vs. just using a regular retaining clip.
So I just bought the 3"lift w/bilstein 5100 from Toytec for my 2014 T4R reading this should I be worried? Do I need to buy anything else? Was going to buy the boss kit but for $350 more couldn't do it considering how much I spent on shipping to Hawaii $300+
fox or new bilstein coilover options I need to clarify before I pull the trig...
For those with negatory feedback on the bushing wear, where do you live and how are you using your 4Runner? Just curious.
Worried about what?
Mostly high desert and alpine, daily off road use, so mine are probably working a bit harder than some others.
Live in Hawaii, Will be driving mostly on street but sometimes on sand.. I just want to make sure this kit will last... my yearly mileage would be something like 8 to 10,000
Whaaaat?
So, you have what, 200k on your 2010 - and NOW you're tired of the suspension? And you're going to spend $Large$ for another 50K miles and trade it on a new 2016 or 2017, and swap the used suspension onto a new vehicle, and put the old suspension back on the 2010? Seriously?
:der: :loco:
:suspicious:
i think you won biggest ******* years ago already. relax.
Keep in mind that the "performance" shocks such as King, RadFlo, Icon, Fox etc are rebuildable for a reason. I would be willing to bet that many who buy these don't really think that through, likely the same who complain about suspension noises after they have done a lift, UCA with uniballs and its 20 degrees out w/ proper lubrication. For that many miles a year I would stay away from the above mentioned brands unless you are doing those miles in terrain like the Baja 1000
Exactly. What most also do not know is Bilstein is a huge global company that could buy and sell Icon, Fox, Toytec with just one month of their revenue. They spend more on R&D than the other guys total revenue.
I guess the same could be said about Japan's KYB, largest shock manufacture in the world, producing a million shocks a week?.
Does it make them better?
Producing products for the masses certainly gives you financial strength, but doesn't necessarily mean your interested in the relatively small portion of specialty market. ICON, Radflo, FOX, King etc dedicate their R&D toward the performance market, filling a higher expectation and charging dearly for their unique products.
Doesn't Bilstein own the high-end disposable product at a reasonable price?
I would buy that if they only made cheap low end shocks. While they do make lower quality shocks for the masses the also make high end shocks for all type of racing. They also make shocks for specific commercial applications. My point is a shock like the 5100 is a decent quality shock for not much money that works in a bunch of different applications. It also will last a long time with no maintenance. Basically what you would expect from a large quality OEM. The boutique shock companies make a good quality shock for specific applications that require maintenance and at a higher cost. I think some of the guys new to off roading don't understand that.
DJNutshell
