S Scofco New member Jan 4, 2004 #1 Has anyone drilled drain holes in the bottom of your frame to allow water and muck to leak out when it gets in? If so, how many should you drill, and how far apart?
L Larry New member Jan 11, 2004 #2 If you drill a drain hole (good idea) what do you use to prevent rust?
