Free 4th gen rear axle/diff assembly, Lexington KY, pickup only
dmaccr
Free 4th gen rear axle/diff assembly ready for rebuild with new gears or locker. From brake rotor to brake rotor and a few lug nuts. The ring gear has 3 broken teeth. ouch! Happened climbing carburetor hill in Slade KY. I can throw in the rear brake calipers as well.
Local pickup Lexington KY only.
Also, I have listed a front diff assembly with 3.7 gears from my 2005 with 120K mi $50
Both axle seals need replacement and drain bolt is a little stripped, otherwise no problems. I replaced the whole assembly with one that has 3.9 gears.
Junkyards sell these for $400. Toyota wants $1000+ for brand new one.
Local pickup in Lexington, KY only.
search words: carrier differential 3rd member axle rear end
Wow wish i had see this been through a few times.. Is this still available?
I have a slight bend in my housing this would be great for me.
When canI pick it up?
d_cool do you still want this rear end assembly? Its got some surface rust but they all do, this one is from a 2003 4Runner. The ring gear is bad on it. To use it you have to swap your third member (differential) into this assembly.
I am tired of storing this thing and I am about to take it to the scrapyard. Let me know soon if you want it. You can pick it up anytime, just let me know first.
It sure is. Let me know when and ill PM you my address and phone.
go ahead and PM it to me so I can let him know what area it is and we can figure out when he can pick it up, you are willing to include the brake parts, etc? He works for Kentucky power so he is all over the place on a regular basis.
Wow, man yes. I called first dibbs.. I sent you a message.
