Front Bilstein 5100 install tips and tricks to help you out!
Thanks for the tips!
I just did this one in my garage this afternoon. Everything was as you said, great job and thanks again!
Just installed
I just did the Bilstein 5100 1.75" lift on my 2008 SR5 and love it. Replaced all 4 shocks at the same time. I was able to get my fronts out without taking the sway bar loose. Only took off the top and bottom shock nut/bolt and bottom 2 ball joint bolts. Did not loosen any of the caster / camber bolts. Pushed the A-arm down enough with a pry bar to pull everything out.
No more nose diving when braking, no more body roll while cornering.. Perfect!
Good write up. I followed the instructions from this forum - OME Install - no spring compressor - Toyota 120 Platforms Forum -
and had good luck. Yours sounds pretty similar, except the other write up didn't require any spring compressors. Should make things even easier for those taking on the project. Just be careful not to cut the lower ball joint dust boot when you use the pry bar. I cut the driver's side and had to replace the boot. Added an extra bit of work that could have been easily avoided.
Side note - my install was on a 5th gen, but the 4th gen instructions served me fine.
WARNING!!! Adding Just because it is not covered and someone searching will find this thread. You will not get any top mounting pieces with your Bilstein fronts. No grommets, washers,....zip, nada, nothing. They want you to use your old stuff....makes total sense to me. I love using old worn out pre-used stuff with my upper end expensive brand new suspension parts. I totally understand how that makes sense! WTF???
This is my big question. What do most people do, reuse the old parts or buy new? If so what parts are needed? It sounds like the OP reused parts with the sharpie marking.
Jason
I just completed this installation on my 2006 4runner v6 4x4.
Bilstein 5100 (set at .85) with v8 stock springs.
The 5100's do not come with the shock mounting hardware. I purchased two sets of the following:
KYB SM5640:
https://www.amazon.com/KYB-SM5640-M...automotive&vehicleId=1&vehicleType=automotive
Installation was straight forward as others have mentioned. I had to wedge some 2x4s on top of the upper control arm and use a floor jack to raise the lower control arm enough to put the lower ball joint bolts back in.
Other than that, it was straight forward for the installation.
hope this helps.
metramm
Jason
KYB SM5640:
hope this helps.
metramm
Thanks for the warning and for the KYB info.
Summit sells the KYB mounts even cheaper, and they're local for me.
https://www.summitracing.com/parts/kyb-sm5640
They also have the Bilstein replacement bushings. I cannot yet confirm correct fit.
Bilstein Replacement Shock Bushings B4-KT1-Z097A00
https://www.summitracing.com/parts/bsn-b4kt1z097a00/
Is it "required" that a replacement bushing kits be purchased? I have a 2016 SR5 so it's relatively new. Is there anything to look for to potentially be able to use my existing bushings? Suspension is out of my area of expertise.
I haven't even done mine yet but I'm pretty sure you can reuse them if they are in good shape. One thing I've heard mentioned is RE: the shock covers....
Make sure to remove the plastic clip if you are using them. If you are not using them, you will need to pull out the metal washer and use it or you will get a gap at the top of the shock. Again, that's what I've read, YMMV.
I lifted with OME coils, but added 5100s...
As I wrote in my build thread, you can use a ratchet strap to pull the lower eye up and over to the correct position and use a prybar to lift it the 1/4" needed to insert the bolt.
Nice write up.
Did you do 2884 coils? How’s the ride over small bumps at slow speeds compared to stock coils?
Can someone explain to me whether the boot on the strut is supposed to be loose on the bottom end of the boot where it meets the body of the strut?
I just picked up a used TRD pro suspension setup, the rear strut boot has a zip tie at the bottom, but it is not tight to the strut body. It easily slides up and down. See blue arrows in the picture.
For the front strut, there is a gap between the bottom of the boot to the body of the strut. See red arrows in picture. I tried pulling it down, but it does not want to stay mated to the strut body. Is this normal?
is there grease coming out? i ran into an issue with new blistein shocks and the moment the mechanic placed them it, it started leaking out. might be a bad shock
There aren't any grease coming out of it. It's looking like the gaps are normal. A friend of mine just bought brand new suspension assembly it and it has the same area where the metal shaft is exposed. Once it get installed and the spring compressed, the metal shaft should no longer be exposed. I was just concerned about a situation where your tires are off the ground and the suspension is fully extended where the metal shaft would be exposed.
shock boot
In my experience the boot is to be zip tied to the body of the shock to prevent debris from getting in there. i would pull the boot down, if able, and zip tie it against the body of the shock. May be worth a little gorilla tape to hold it in place if it keeps sliding off. If you run it without a boot it will void Bilsteins warranty.
If you go mudding allot then you may want to keep it loose so you can pull it up and rinse it out. Be sure to periodically clean it out if you keep them loose.
Keeping it clean is a good key to keeping them working well and not leaking.
So I asked some questions here on this board, and decided to do this mod myself. 92k miles on the stock suspension, and they were worn out. I bought the shocks from Wheelers Offroad. They were Bilstein C475HO Front Shock Set which were $175. With UPS shipping, the grand total was $197. That is cheapest you will find anywhere else (trust me, I looked). I followed the directions in the PDF that I attached to this post (also included is a pdf of the parts exploded view and their torque settings). Here are a few things that I learned and some that I observed which could help out anyone thinking of doing this. This was my first suspension, and boy was it easy! Only took 3 hours with nothing but hand tools. PRINT OUT THE BELOW PDF'S!
1) If you follow the below directions, you will NOT have to remove or loosen ANY suspension pieces except for removing the sway bar, which is a total of 4 bolts and 2 nuts.
2) Do youself a favor and get an impact wrench for those bolts that just dont want to break free after 6 years and 92K miles. I rec'd the electric one that I bought from Harbor Freight. It saved my @ss! I actually found a coupon for it for 50% off! Here is a link: Model #45252
Also get this set of impact sockets (Central Pneumatic Metric). Here is a link: Model #94221
3) When you go to take out the old strut/spring combo, push down on the A-arms to get out bottom of the strut to come out of its mounting point.
4) To get the strut assembly out without removing or loosening anything else, pull up on the A-arms slightly and thread the strut assembly out between the steering arm and the lower A-arm (just turn the strut with the steering arm inbetween the coils of the strut. Trust me....you will see what I mean!)
5) The 5100 struts where already set on the 3rd highest setting, which is suppose to give a 1 5/8" lift. It raised the front of my truck EXACTLY that after install with the OEM springs, and the rear is now only a 1/2" higher than the front. FRIGGIN SWEET!
6) Make sure to mark the upper spring seat, rubber washer, and the top part of the spring to insure that the same part of the spring is facing out when you transfer all of those pieces over to the new strut. I put an ARROW in silver Sharpie to denote the outside of the assembly, and 2 lines to line eveything else up. When you put it all together with the new strut, make sure the bottom of the strut that mounts to the lower A-arm is at a 90 degree angle, as it can be a real pain to turn it to get it back into its mounting point.
7) I used a coil spring compressor which I also bought from Harbor Freight for $9.87! I put Moly grease on the threads to help it along, and it worked great. The threaded rods started to bend while tightening, but they held up great. Totally worth it. I rec'd using the safety hooks, however I did not. Here is a link: Pittsburg Model #3980
8) I placed the top of the new assembly into the top mounting bracket, and loosely placed whatever nuts I could onto there respective bolts. Since the new 5100 strut and spring assembly is about 1/2"-3/4" longer, I had a hard time trying to figure out how to get the bottom of the strut into its mounting location. I eventually figured out that you can use a long crowbar and wedge it between any coil of the spring you can get ahold of and the topside of the upper A-arm. When you pull down, you can really torque the hell out of it and the strut should slide right in. You may want someone else to help you out, and make sure TO KEEP YOUR FINGERS CLEAR OF ANY LOCATION WHERE THEY COULD GET PINCHED IF THE CROWBAR SLIPS!!! I was able to get the whole thing in and the lower bolt in without too much hassle.
9) Torque everything and reinstall the swaybar
10) Take it to an alignment shop ASAP! I had NEVER had an alignment down, so my numbers were way off. NTB (National Tire and Battery) did mine. Funny thing, they wanted $129 for 1 alingment, or $209 for 5 years worth (1 every 6 months)! I chose the later
Good luck. This was super easy, and was able to buy all the parts, plus the tools, and get an alignment down for about 50% of what this would cost at the dealership, and the parts that were used were FAR superior to OEM crap.
Please access the below link for the PDF's. They were too large to upload to this site.
Toyota - Folder Shared from Box.net - Free Online File Storage
The PDF’s is a must ! Thank you it was so easy to put my lift on. All of these videos on YouTube are taking off the front stabilizers and upper/lower ball joints. You don’t need to do that!!
