1994 Toyota 4Runner SR5 4WD (2nd Gen)
Background problem....
Out of nowhere, after owning and driving it daily for 6 months I hooked up my utility trailer and didn't get 15 miles down the road and noticed the engine bogging down. I was in 4th gear and all of a sudden i can't get it to accelerate so I kept down shifting until everntually I pulled into a gas station and came to a screaching hault. The pedal was as hard as a brick!
I had tools, and I could smell the front brakes were really hot (both sides) so I slightly open the front brake line on the Master Cylinder and it sprayed brake fluid past me 5 feet. I tightened the line back down and had someone pump, pump and hold the brake pedal down and while holding I did the same thing and it again released all kinds of pressure, I tightened down the line again and brakes were back to normal. It happened 2 more times before I got it back to the house.
Round 1...
Master Cylinder? I thought so...I was wrong. I replaced it with one I got from Advance Auto and after pain stakingly learning how "bench bleeding" is done, it had no affect. I figured I had gotten a faulty MC so I returned it and got another one and with still would lock up after only driving for a few minutes. (Bench bleed both correctly and re-bleed the whole system starting at the furthest wheel RP,RD,FP,FD) It didn't make the problem worse it didn't change anything.
Round 2...
Took it to a local mechanic that has a ASE certified shop. I got the suggestion that it was probably the front calipers were both bad and the front rubber lines must be bad also....he was wrong! I went and picked it up having to bleed the MC twice on my 8 mile drive back to the house, only stoiopping back at Advance Auto to pick up the front rubber lines and new Calipers with new pads in them. I figured WTH I'll throw some cash at it.
I started with the front rubber lines going from the body to the frame (cheapest first) and no change at all!!! So then I thought, fine I'll do the calipers. No change, but I new all along the Mechanic was just throwing money at a problem because the symptoms were not text book. I shouldn't have followed that lead!
Round 3...
Brake Booster? Not sure of all the symptoms of this, but read in a few places that it can cause the pedal to get hard. I now am on a strict budget cause I foolishly wasted my budget on Calipers I didn't need. (Not bitter, just want this fixed, I really love my Toy!) I found one that was parted out of a '94 4Runner so I bought it cleaned it up made new gaskets for it between the Firewall and the MC and that seemed to fix it. I locked up twice after the booster replace and then nothing I have put 500 miles on it hauled a couple tons of mulch behind it without issue and then 4 days ago the problem came back like it had never gone away!!! WTF!!!
On a side note... The dreaded LSPV Valve. I removed it during this also and put in the Manual Proportioning valve from Jeg's. I mounted it just before the rear line connects to the MC. Why did I change it? I could bleed the valve on the LSPV, but not the rear brakes. I tried it with the key in the on position also (some out there had suggested that) before anyone asks. After the bypass the rears were bleedable again.
Round 1...
Round 2...
Round 3...
