front coil overs
If you install a spacer lift on factory (assuming worn out springs) it probably will be around 2" - 2.5" I would THINK.
Don't buy that spacer kit. Thats a top mount spacer which will cause your upper ball joint to bind a commit suicide. It will also cause the spindle to smack into the factory spring which will make a nice loud clanging noise.
Preload spacers are a much safer design but aren't exactly ideal either especially with older coils.
Got a budget you are looking to stick to?
Obviously great advice from, Dylan.
My tip would be to watch the classfieds over on TacomaWorld. I love my [MENTION=44448]ToyTec Lifts[/MENTION] Boss Coils, but if I knew I could have picked up some rebuildable coilovers for <$300, I would have gone that route.
coilovers
Well..... thanks for the advice.
I had preload spacers on the 4runner springs and they were tight as hell. never absorb an impact on the road.
I now have 2000 4x4 tacoma springs and Bilestein strut and it is magnificent in absorbing bumps. Now I can go over bumps like driving a lexus car. The tacoma springs are soft and have a different winding pattern (coils are closer at the top and far at the bottom). If I add the same preloaders to this set-up do you think I'll get a lift?
nissanh
What are you guys referring to as preload spacers? Since you can't preload the coil unless the shock is fully extended (drooped) all the time, which I would imagine would be bad since you won't have any down travel.
nissanh
Do the Tacoma coils give any lift?
:llama:
nissanh
The coil pattern tells you they are progressive rated. The closer wound section at the top is softer, and the coil gets stiffer as the distance between them increases. I wonder why Toyota never used progressive coils on the 3rd gen when they used it on the Taco . . . silly Toyota
Wait....I didn't know the tacoma also had a progressive rate spring...but they dont add lift? I was looking at tundra springs but I would prefer <2" lift. Like 1.5" or so but with progressive rate. What is the length of the stock 4runner front spring?
coilovers
Found the preloads I removed from my previous struts.
The strut/spring shown is from the tacoma.
