thirstyturtle
Need some help here, fellas.
New to me (about 3 weeks ago) 2000 4Runner 4x4. Had a CV boot bust on me last weekend (driver's inner), changed it last Saturday using a new Toyota boot and Toyota grease. Drove it all day Sunday, including a couple miles on the beach, without issue. Then on Monday or Tuesday my wife noticed a "clunking" noise coming from the front end over bumps sometimes and a separate steering noise when parking. While under the car to check out these noises I noticed that my new CV boot had a very small leak from the fatter end of the boot (closest to differential) so I've gotten a new better clamp I'm going to switch out today.
The clunking noise is easily recreated by bouncing on the front drivers side of the car and it sounds like it's coming from the bottom center of the front of the truck, like right under the engine. The clunk occurs on the "rebound" of the suspension, so on its way back up only. I can't get it to "clunk" by bouncing on any corner of the car except the front driver's side.
Here's a video (from behind the front left tire and then in front of the car):
The steering noise I've isolated to only occurring when going forward and turning to the right pretty hard, not necessarily full chock, but probably 80% and beyond and it gets slightly louder the further you turn the wheel. It sounds an awful lot like a brake dust shield rubbing or dragging against something but I haven't changed anything down there and can't find where anything is rubbing it.
Here are two videos
From out the window (hard to hear the noise):
From in front of the car (faint but when the truck is right in front of the camera you can hear the dragging noise):
Any help would be greatly appreciated. If it helps, I didn't have any trouble with the CV boot job but it was my first time doing one of those. I torqued everything back to spec and would be surprised if either noise had something to do with the job but both noises did start just a couple days after the job so it may not be coincidence. Also, I've checked the power steering fluid level just to eliminate a rack issue and it was right on at the correct level.
All of my mods can be seen in my signature if necessary.
Here are two videos
