front end noise in 2wd only
4sports
On my IFS 2nd gen 3.0 with auto trans and ADD front diff,
I am getting a grinding/rubbing/buzzing noise from the passenger side front that is somewhat intermittent. Small bumps in the road will either start or stop the noise at all measurable speeds. I have eliminated the brake calipers/pads and wheel bearings as possibilities. When shifted into 4WD, there is a chirp and then the noise ceases. I figure this must indicate a problem in the diff or CV axle when freewheeling only. Maybe the ADD isn't fully disengaging? I am going to remove the cv axles and take a closer look at those. Boots are not torn though, and there doesnt seem to be any play at the cv joints themselves.
What are your thoughts? If the problem is diff related, how involved is a bearing job? a rebuild?
I had what sounds like a similar issue in my 89. Turned out that the hub wasn't unlocking properly. I was getting the noise when I was reversing in 2wd. I ended up going with some warn hubs, and haven't had any issues since
