MDTrailrider
So my 4Runner has been royally screwed by a Toyota dealership because my 6 month old clutch which was replaced by an independent repair shop with a good reputation may have been a poor job or received a defective bearing.
So Wednesday morning I get under the truck to grease the propeller shafts after finally getting it back Tuesday night and I can't find the "B" fitting for the sliding yoke on the front propeller shaft at the transfer case. When I move on to other joints I realize the shaft is backwards when I find the fitting and yoke at the front differential. This is according to the Tacoma shop manual. I lost my access to the 4Runner shop manual. I have 4 questions:
1. Does the shaft go in the same direction according to the 4Runner shop manual? I would be stunned if it was the opposite between the Tacoma and 4Runner. This was the first time I greased the shafts myself so I never looked that close before my clutch was replaced.
2. How urgent is it to get it switched back around if it is backwards? I'm not planning to use 4 wheel drive for a couple of weeks.
3. Does it really matter if it's backwards in 2 wheel drive?
4. Does it really matter if it's backwards in 4 wheel drive?
I want it right but I'm not sure it's wrong without the 4Runner manual or urgent in anycase.
