Front rake
sdhobbs
Hey guys do you think I have too much front rake? Or am I over thinking this?
null_zps7fd4313f.jpg~original
Looks perfect to me with the bit of rake, but it's all preference IMO. Do YOU like how it looks? Or you can just wait a little longer and ask the cop for his opinion when he comes to write you a ticket for blocking a handicap zone :)
First give it some time to settle.
Second my opinion is to have 1" of rake, but I don't load up my truck with tons of gear either.
Kinda wish it was a little more level, but I don't want to end up with reverse rake either. It rides perfect so maybe I'll leave it as is, just needed some confirmation, thanks!
I personally like it more level than you have it now. I've never liked the +2" rear coils because you have to crank up the fronts more than i'd like just to sit close to level. I went with 1" rear coil from CSS to achieve rear lift and didn't have too much of a UCA angle for levelness
I thought the Icon lift would level the truck, that's what the shop that did the install told me. I may go back and see if they can crank up the fronts a little. Just wanted to get some feedback first, thanks!
I noticed you are in SD, you should check out the SoCal forum on this site, we just did a cool evening trail ride up Santiago Peak. We had about 4 5th gens come out.
I didn't realize there was a socal section on here. thanks
i had ICONS on my FJ but didn't like having to crank them up due to the limited down travel afterwards and UCA angles
I have a similar rake with my OME 898's in the rear. I have my Icons cranked up quite a bit in the front with no ill effects after a year. I got the heavy rear coils in anticipation for a rear bumper in the future. I also can not stand a reverse rake when you load your rear end down.
You should just crank them up yourself and get another alignment. It is a simple task as long as you have a spanner wrench.
What's CSS? And do they sell them online?
I have Icon Stage 2 with MT long travel in the rear and when i first installed the lift my truck was level, but now i start adding some weight to the front and i have the rake. The front is heavier so it will settle faster then rear, i know some people put heavy load in the rear to help settle it. I'm waiting until i put full skid plates and then going to crank the coilovers to level the truck. BTW truck looks good.
Daniel Frost
