Front Recovery Point Interest Thread
Are you interested in a group buy for bolt on front recovery points?
  • Yes
    Votes: 146 78.5%
  • No
    Votes: 40 21.5%
  • Total voters
    186
Any 4th gen V8 recovery points available or coming?
yes! go to the website and look under recovery points. 120 series point for you. If you have an 06+ it does requite removing the factory loop. The 150 series points will also work and not require any cutting.
Front recovery loops
No fear mongering, just providing an upgraded solution. Just like 75% of what we bolt on our rigs.
You're right, it was a 120 platform, either a FJ, 4th gen, prado, or GX. The design on the 5th gen is the same though. I've attached a pic of a 5thgen for reference.
There are two of these points on the front. One on each side of the frame. There is one in the back but you can easily add a second point using threaded holes that are already there. It's the same as the other rear loop. Loop and 2 bolts available from the Toyota dealer.
If you use a bridle on both tie down loops you can cut the load to each side in half. With the right chock block the load will be equal on both sides. Here's a thread showing how to make a sturdy bridle, where to buy one and what it looks like in use (photos).
How To Make A Bridle
Page 8 of this thread shows the tie down loop parts and how to install it.
Recovery Gear Options
For the back tie down loop you have to move the exhaust tip forward or turn it sideways behind the tire. A side exhaust has the advantage of not blowing exhaust out the back where it can get sucked into the back window if it's open.
Appreciate the input, my business revolves around my recovery equipment that is also made here in Houston of US made raw material.
So if you’re looking to add a bridle, rope, kinetic rope, etc to your loadout, please feel free to browse the site at the link above and let me know if you have any questions.
KDSS compatible
Pending the brackets on resis Ima give that a maybe. Email me photos and I can give a good idea. [email protected]
Attendees to Lone Star Toyota Jamboree will be the first to have the opportunity to snag these. I’ll have 10 sets available there, once I get back they’ll go live on the website.
I don't think they will fit.
D'Angelo
