Front Right Trimming
Zadams31
Currently have 265/70/17 tires that rub slightly on the front right screen on my 2007 sport 4runner. Guys that have bigger tires how did you fix this problem? 2 body shops have suggested I don't completely take it off. I'm trying to go up to 275/70/17 TKO2's. They slightly rub the UCA's but I can get spacers to solve that problem.
[MENTION=126146]Zadams31[/MENTION], when you say "front right screen", are you referring to the wheel well liner? I am assuming that your coils are sagging which is contributing to your rubbing problem (by 100k, the 4th gen front coils sag). What most of us do, is simply unbolt the lower half of the front portion of the wheel well liner, push it forward, and re-attach (read bolt) further in the lower bumper shroud. Problem solved. If you are not referring to the wheel well liner, than I have know idea what you are talking about.
Haha yes I'm referring to the wheel well liner, I just wasn't sure exactly what its called. I will give that a shot thank you. Also, do you suggest replacing the coils as well? I have Xreas system and don't know if I would have to replace the whole thing?
H.Sikina
