Front Sway Bar Relocator?
sporty87
Do I need front sway bar re-locators for my 2010 SR5 4 Runner that has the Bilstein 5100 front adjustable shocks set at the 1.750" setting. Also do I need Uca's if the alignment came out okay and have no problems? If I need the relocators where do I get them? Thanks
Sway bar relocaters are a good idea to get the sway bar closer to it's original position/angle, but if your sway bar is not "banging" into anything under there, you may be able to get by w/o them.
UCAs not required if your alignment can be put into spec. I'd be interested to know what your caster is set at. Did they give you a before/after alignment sheet? At 1.75" I do believe a caster of 2.5 or even a little higher is attainable with stock UCAs. I was able to get caster around 2.8 with a lift I had in the past - which was around 1.75-2"
brendaglores
