Front Wheel Bearing Hub Assembly
mlc2000
Hi all,
Yes, I have another problem.
My 2005 SR5 4runner is having front wheel bearing issues again. Back in March 2014, I replaced both front driver and passenger side with Bluepit bearings. Now one or both are going, I'm not sure yet. Bluepit only had a 1 year warranty and to me, 2 1/2 years is too short. From the two sites below, it appears that they're selling the hub and bearing separately and I don't have a press to put them together.
Anyone know where I can the whole hub assembly?
Wheel Bearing/Hub Assembly-Front for Cars, Trucks & SUVs
Advance Auto Parts: Search Results for wheel hub bearing
Tanks in advance!!!
There is a user on here. [MENTION=100129]nj636[/MENTION] he presses the bearing and hub assembly together. I just ordered 2 last week. He has a thread somewhere on here. Only one I have seen that offers the whole assembly already pressed together.
What kind of issues are you experiencing?
Loud grinding noise coming from the wheel area. Noise gets louder as I pick up speed. I had this issue back in '14 on both wheels and replaced the wheel bearings. Not too thrilled since the original bearings lasted 9 years while the two I replaced only lasted 2 1/2 years. Though again, I haven't figured out which one it is yet.
I don't want to pay the dealership $700 plus tax for it. Ridiculously high price in my opinion. And yes they quoted me on that during my mv inspection.
Well you're on the road to a $700 bill it seems - not that I'd be willing to pay that either. For the record I used eBay hub/ bearing assemblies, hope they last a few years at least.
$330 shipped gets you two hubs, cotter pins and the axle nut :thumbsup:
Exactly why you don't replace original components with junk.
Have you had issues with BluePit before? I've heard mainly good things about them to be honest with you.
I went with Marion's offerings because he was a forum vendor and sold the whole assembly for a good price and his parts were good quality as well.
I had to replace my bluepit wheel bearing assemblies also. I had maybe 25k on them. Maybe the Timkin bearings in them are made in China now.
I replaced them with ones with the Toyo bearings in them.
Toyo meaning Toyota? That would be the Moog bearing.
Longevity depends on the installation as well. If you don't torque the axle nut the bearing will fail prematurely.
I can't keep a wheel bearing on my drivers side for some reason. I am on my 4th in 2 years, replaced two in the last year and this last one is bad already after a couple months of on road use only....Marion warrantied one for me, but it's not fair to him or the other guy here to ask them to warranty when it's an actual issue for some reason. The last one I had pressed together at a shop the guy messed up the threads and I didn't see it until trying to install on the knuckle, which subsequently really messed up the threads. I was able to get a tap and die and clean them up, but it is bad enough that now I will have to replace the spindle too. I don't understand why it keeps going bad, guys with 35's and offset rims aren't having these issue's. I have wheel adapters, but with the offset of the rims and amount of spacer I stick out 1.25" further.
Actually it's probably either a Koyo or Asin if we're talking factory part.
That's weird... how's the spindle look?
Are you torquing the 35mm nut ?
I have seen the Moog's on OE assemblies.
For Bearings? Wow... interesting, I don't recall Toyota every really using Moog as a factory parts supplier. Ussually it's Asin, Koyo, and/or Denso for most of their hardware stuff like that.
Yes, made sure everytime.
Visually it looks great. All mating surfaces sealed great, were clean and free of defects. New seals everytime, always torqued correctly, can't see anything wrong. I found a junk yard that is selling the whole spindle with bearing/hub assembly and abs sensor for $125. That's my next move. This last wheel bearing has only seen road time to. Zero offroading!
Sent from the drivers seat of my 05 4runner.
charlesz
