Front wheel bearing/hub
Grodd
Hello, so quick back story. Recently bought 2002 4Runner limited 4wd and decided to redo the whole front end due to age. Did lower control arms/bushings tie rod inner and outer, lbj ubj, shocks, wheel bearing and prob a couple other things not mentioning. Ok so I noticed outer tire feathering on my new BFGoodrich ko2. Do I took it back to alignment shop and told them story, had I aligned a few times before and while tech was doing alignment he noticed that the passenger side wheel had play that didn't effect opposite side, indicating wheel bearing, as tie rod looked tight.
So my question:
I replaced with koyo wheel bearing and had press work done at local machine shop.
Has anyone had problems with these bearings?
Or has anyone heard of play appearing due to hub itself or knuckle? This seems unlikely to me as it is an auto hub so has no spinning parts.
Also there is no noises associated with this
Any thoughts?
AndiGarage
