FS: 1995 4Runner V6 manual, lifted, locked
suppra87
I have finally decided to part with my 2nd gen 4Runner. Bought a 3rd gen recently and well, it’s just time to move on.
Truck is a 1995 Toyota 4Runner SR5 3.0 V6 and 5-Speed manual transmission. It has 252k miles on it but the engine and transmission were replaced about 70k miles ago. Obviously a new oem clutch was installed in the process and the timing belt and water pump were replaced. The engine currently needs valve cover gaskets something fierce. And the ABS light is on becasue it needs a rear axle speed sensor.
Suspension was installed 2k miles ago. OME 2.5” lift, OME soft ride shocks with heavy duty rear springs, +400LBS load I think. Downy Torsion bars. All 4 ball joints and all 4 sway bar end links were replaced with the lift install.
The front brakes were completely rebuilt 5k miles ago. Front hubs were completely re-greased, new OEM brake calipers, OEM rotors and pads. Brake fluid completely flushed at this time as well. Rear axle has a stainless braided line.
The front differential is geared 4.88 with a Detroit Trutrac locker. The rear differential has an ARB air locker BUT is geared 5.29. The truck needs to be re-geared in the front or rear because of this. I’ve carefully used 4wd a couple of times like this at sub 5mph but it NEEDS to be fixed.
ARB front bumper, rear bumper is a Trail Gear tube bumper that's bent down from my boss's boat. Wont try that one again. Also has welded on Trail Gear rock sliders. Sliders and rear bumper have been coated in POR-15. The entire frame has been coated in POR-15 many times. This frame is completely RUST FREE, extremely solid. The body does, however, have some rust bubbles above the rear fender wells.
Interior is very good shape except for driver seat bottom bolster and a couple cracks on the dashboard. Everything works including ice cold A/C. Has a relatively new stereo and is wired for an amplifier and sub but I never had one in it. The rear hatch window glass is disconnected from the regulator on the driver side. I put on a steering wheel from a MK3 Supra, all the cruise control buttons still work. I have the original steering wheel as well.
I bought this truck from the second owner who had put 200k on it. He cried when he sold it even knowing it was going to an enthusiast. I really hope I can pass this great truck on to a fellow Toyota guy who will put it to good use!
I was asking $6500 locally but may have been too ambitious with the small tires. Asking $5500 OR best offer. Located in Pasadena, MD.
128f3e43-8d1c-4b90-a4fa-11385f1d8247_zpsuy73dvqf.jpg~original
IMG_1036_zpssqy9pu93.jpg~original
IMG_1035_zps7w12xnso.jpg~original
IMG_1040_zpsqy8au6ue.jpg~original
IMG_1047_zpsdxd22arm.jpg~original
IMG_1051_zps9jm9tgo4.jpg~original
IMG_1050_zpskw1ispv4.jpg~original
IMG_1049_zpsghs9s1jd.jpg~original
IMG_1053_zps8z6ouaip.jpg~original
IMG_1054_zpsvhsblf20.jpg~original
IMG_1058_zpsewfrcxtn.jpg~original
IMG_1057_zpsfjldeuml.jpg~original
IMG_1046_zpshccfmrcw.jpg~original
IMG_1045_zpsqiyqucxx.jpg~original
IMG_1044_zpsbm5xpq6x.jpg~original
IMG_1043_zps0uofzvcz.jpg~original
IMG_1041_zpsf9wofmwu.jpg~original
IMG_1039_zpsfolr2ylq.jpg~original
IMG_1038_zpsudqnchpc.jpg~original
Truck looks very nice, and the lockers are a big plus, but an immediate gearing change is a major consideration for potential buyers. Even most hard-core DIY owners don't have the capability or specialized tools to set up new gears, which means a big labor expense right out of the gate. Five grand for a 2nd Gen is reserved for nearly perfect rigs which need nothing. Best of luck, friend.
erinobr2000
