FS: 1999 4Runner Limited 4WD RR Diff Lock- Columbus, OH, $7200 OBO
THatfield
Silver 1999 Toyota 4Runner LTD
5VZ-FE 3.4L Twin Cam V6
4 Speed Automatic with ECT
Multi-Mode AWD/4WD
Rear Differential Lock
Silver 1999 Toyota 4Runner LTD. 5VZ-FE 3.4L Twin Cam v6, Automatic transmission, and Multi-Mode, AWD/4WD Transfor case. Has Rear Differential Lock. Multi Mode 4X4 has H2, AWD, H4 and L4. Truck has been modified and used off road. Has around 4" of Lift, via FZJ80 coils in the rear and OME 883 Coilovers in the front. Running 285/75/16 Mastercraft Courser MXT Mud Terrain tires. Has 42" LED light bar, 22" LED Light bar and LED pods front and rear for superior offroad lighting performance. Rock Rails installed, Cobra 18WXSTII 40 Channel CB with Weather and Firestik II Antenna. Scangauge II for reading optimal engine and transmission temps as well as other parameters. 2003 Subaru WRX bucket seats in the front, original tan leather split folding bench in the rear. Automatic Climate Control does work, but A/C is weak. Might need a recharge, and rear heater works well. All power windows, locks and mirrors work as well as rear window and sunroof. Straight piped exhaust, it is loud but has a good sounding growl. Does have dents and scratches from offroading, but is a great rig. Frame is solid and straight with hardly any rust, a rare sight for trucks in the north. Lots of work has been done and should be a sound vehicle for on and offroad use for miles to come.
Maintenance performed:
- Every fluid has been changed (ATF, Front and Rear Diff, Transfer Case)
- Oil Change every 3500 with Full Synthetic and Toyota Filter
- Idle Air COntrol Valve
- All new brakes including master cylinder.
- Rear parking brake has been rebuilt
-Timing Belt at 150k
-Exhaust work
-Plugs, wires at 150k
-Transmission cooler (bypassed radiator, so no pink milkshake)
-Fuel Filter
-Mass Airflow Sensor
-Battery
-Alternator
-Starter
Any questions text or call (text preferred please) Wes at
Area Code eight six five, eight zero six, three six one four Asking $7200 OBO.
Located in Columbus, Ohio. PM me if you'd like more pictures, I have some on my computer.
wayblom
