Mulky
For sale
2002 Toyota 4Runner SR5 4wd
208,xxx
Thundercloud Metallic
$7000 NO TRADES
Located in Nicholasville, KY
Please read the entire listing, as i will try to be as detailed as possible, and cover any questions you might have.
For sale is my 2002 4runner. I have owned this since July 2015, and bought it from the second owners bone stock with 176k on it. It has been my daily driver up until this week when I purchased a 5th gen 4runner. It has never left me stranded, and the only work that has been done is regular maintenance. Cold a/c, and hot heat.
Maintenance:
-Gates timing belt/water pump at 203k
-Valve cover gaskets at 203k
-NGK plugs/wires at 203k
-Energy suspension steering rack bushings at 208k
-Tires rotated and balanced at 208k
-Alignment at 208k
-Aisin drivers front door lock actuator
-Oil changes every 3k with Mobil1 5w-30 and OEM filter
Modifications:
-Toytec 3” lift, with Fox 2.0 rear shocks
-Toytec diff drop
-FN Wheels five star 16x8 -25
-General Grabber AT2 285/75/16
-Addicted off-road front/rear bumpers
-Cheap Amazon led pods (don’t always work)
-SRQ Fabrications mesh front grille
-Clear corner lights
-LED tails lights
-Air Raid intake
-Borla XR1 muffler
-B&M 70268 Transmission cooler
-LED dome/map lights
-Red LED gauge cluster/climate control bulbs
-Scan Gauge II
-Pioneer AVH-200EX headunit w/Bluetooth
-Weathertech in channel rain guards
-Weathertech front/middle floor mats
-Covercraft windshield screen
Cons:
-Has some rust. Frame was professionally patched in November 2016 above the passenger rear trailing arm mount. Fair amount of surface rust underneath. Never got around to cleaning/coating it all. One spot of rocker rust starting to show behind the passenger front wheel.
-E brake doesn’t work great. Probably just needs adjusted. It never bothered me since it’s an automatic.
-Power antenna doesn’t go up and down. Has no affect on radio reception.
If you’ve read all this and I still have your attention, then give yourself a high five.
This has been my baby for the past 5 years, and I hate to see it go. But unfortunately, I’m not able to keep it along with the new 5th gen. I tried to answer any questions, but feel free to message me with any others.
$7000
NO TRADES
208,xxx
$7000 NO TRADES
Maintenance:
-Alignment at 208k
Modifications:
-Toytec diff drop
-LED tails lights
-Air Raid intake
-Borla XR1 muffler
-Scan Gauge II
Cons:
$7000
NO TRADES
