FS 2010 5th gen 4runner BUILT $19500 Walnut CA
Dlak
136K MILES
1. Total Chaos adjustable rear links
2. Icon suspension dynamics front extended travel remote res 2.5 shocks
3. Icon suspension dynamics rear piggyback extended travel 2.5 shocks
4. Total Chaos lower link skids
5. Total Chaos upper control arms
6. Total Chaos weld on spindle gussets and sway bar mounts
7. Icon suspension dynamic stainless steel lower shock shin guards
8. Demello Offroad single hoop front winch bumper
9. Demello Offroad bolt on hybrid sliders
10. Outdoor logic modular roof rack ( side rails are removable for RTT mounting)
11. Outdoor logic rear tire carrier
12. Arb awning (could use a new one)
13. Onboard 2.5 gallon air tank and dual viair compressors
14. Safari Snorkel
15. Body mount chop
16. Procomp Wheels and Nitto ridge grappler tires 295/75/17
17. 10k smittybilt winch needs replacement
18. ARP extended heavy duty wheel studs
19. ABR sidewinder secondary battery tray
Pros: Thousands in parts and the truck runs perfectly
Cons: Trail scratches in clear coat, rear tire carrier rattles a bit( easy fix), the steel could use a coat of satin spray), rear tires rub on full tuck( spacers are 2" better to remove or go 1") winch solenoid is burnt out) Front spot lights need to be replaced. Includes ABR sidewinder secondary batt tray that needs to be installed. Have not used the compressors in 4 years and not sure if they run but the tank is mounted underneath the rig were the spare tire was located and has the mount points ready to go for replacement compressors.
CONTACT David 626-235-4288 Walnut CA
