FS: 2013 4Runner SR5 Premium | 4WD | AL | Bilstein/OME Lift, SPC UCAs, RCI Skids - 256k mi, $15k OBO
3point4par
Athens, AL Rust Free Rig $15k
List of aftermarket parts
Suspension
Bilstein | OME Stage 2 RTR Lift Kit – 5th Gen 4Runner | FJ Cruiser (10-14)
Front Coil Configuration LD – Light duty coils, intended to be used under stock vehicle weight. Option 1: OME 2884: LD, 1.5″ lift
REAR COIL CONFIGURATION LD – Light duty coils, intended to be used under stock vehicle weight. Option 1: OME 2889: LD, 2″ of lift – 30% stiffer than factory
SPC upper Control arms
Rear Panhard Trac Bar
BOTCK- BOLT ON TRACKBAR CORRECTION KIT $205
Brake Lines
YM | 2003+ Toyota 4Runner | GX470 | GX460 | FJ Cruiser Extended Brake Lines - Front and rear extended brake lines - BRAKE LINE COLOR Smoked Black $135
Bump Stops
Front rear of lower control arms
Energy Suspension- 8.9104G REAR BUMP STOPS
Rear spring and frame
Energy Suspension 9.6104G Coil Spring Isolator Set
Energy Suspension Rear Coil Spring Bump Stop/Isolator 8.9105G
Wheeler's SuperBump Rear Bumpstop Set for 03+ 4Runner and 2007-2014 FJ Cruiser (WOR-306952)
Skid Plates
Full Skid Package Deal | 10-Present 4Runner
Material 3/16" Steel - Black powdercoat
Bumper Filler Plate | 10-Present 4Runner
Material 14 gauge steel
Catalytic Guard | 03-Present 4Runner / FJ / GX
Material 1/4" 5052 Aluminum - Raw Metal
Fuel Tank Skid Plate | 03-24 4Runner / GX
Rear Shock Mount Skids | 10-24 4Runner / FJ / GX
Lower Link Skids | 03-24 4Runner / FJ / GX
4Runner Differential Skid / 5th Gen / 2010+ × 1
Rock Sliders
Rock Sliders | 10-Present 4Runner
Top Tread Plate - Add Top Tread Plate
Finish Satin Black Powdercoat
Slider Angle 20 Degree Sliders (Standard)
Wheels
Method Bead Grip
706 | Method Bronze × 4 | 17x8.5 | 6x5.5 | 0/4.72" | MR70678560900
Lug Kit | 4 Wheels | Full Kit - Black × 1 | 6 Lug | 12x1.5 | EXTENDED | LK-W56015SEB ET
Tires
BFGOODRICH® All-Terrain T/A KO3 LT285/70 R17/E
Recovery
Ironman 4x4 America
Toyota 4Runner 2010+/Lexus GX460 Rated Recovery Points
MaxTrax Xtreme Boards, Orange (2)
Hi-Lift Xtreme Jack 48"
Exhaust
Flowmaster FlowFX Cat-back Exhaust System 717805
Granatelli Electronic Aluminized Mild Steel Exhaust Cutout System for 2 1/2 in. Single Exhaust (Slip-Fit)
Engine Bay
4Runner Engine Bay Accessory Tray - Driver Side / 5th Gen / 2010-2019 × 1
Backwoods Adventure Mods Windshield Fluid Reservoir Guard Skid Plate (10-23 4Runner)
Item #: TR17428
HPS Silicone Post MAF Air Intake Hose Kit; Black (10-23 4.0L 4Runner)
Item #: TR23504
Interior
ScanGauge III
67 Designs 4RunnerRail
Yaesu FTM-400XDR Ham Radio Dual-Band Mobile 144/430MHz Transceiver
Roof Rack
LFD Off Road Ruggedized Aluminum Extrusion Crossbar - 5th Gen 4Runner × 3 and Traction Board Mount
Exterior
Spyder Toyota 4Runner 10-13 Projector Headlights
emilygrace28
