FS 2nd gen 4runner on tons $4500 Ruffin NC
NCrunner0
Selling this to fund a mild build of my 4th gen, unless my 4th gen sells first, what? I don't really know what i am doing but here it goes!!
$4500 obo
91 4runner, 143k miles, recently done-front and rear brake overhaul,wheel bearings and seals replaced, diffs serviced, new headlights and turn signals and muffler. Starts every time, rides and drives well for what it is!! The body has a few small rust spots but nothing bad, and the frame is solid. Interior is really nice, seats in good shape, no dash cracks!! You can tell where the ps door and fender have been buffed, just need to do the rest and the paint shines up well for a 91.
Power windows (even back window works)
Power locks
Rear heat
New fuel pump
New battery
A/C needs recharging
Swing out tire carrier
3.0 V6 automatic
Dodge Dana 60 Front axle with 5.13 gears and a 35 spline Detroit. Stock shafts
High angle driveline Dana 60 to Toyota pinion flange.
Ford Dana 60 rear axle loaded with 5.13 gears and 30 spline spool with stock shafts rear disk conversion brackets included not installed
Trail Gear rear Leaf spring swap with 5.5 inch springs
All pro offroad SAS 5 inch springs and shock hoops
Sky manufacturing pitman arm
Sky manufacturing brake booster adapter with GM 3/4 ton master.
255 LPG external fuel pump included
Five 37x12.5x 16.5 Humvee tires (like new)
Five 16.5x8.25 procomp rock crawler wheels
Ballistic Fabrication High steer arms
Ballistic Fab dana 60 diff covers
Ballistic Fab high steer crossover kit. With one ton Chevy tie rod ends
Steering box has been relocated to clear the steering.
Custom Square Tube drive shafts front and rear Cv in the rear. (Front shaft sits at 27 degrees but does not bind yokes have been clearanced and has 106 degrees of movement before bind 53 degrees every direction.
The driver side hub is currently in-op, the cam inside the hub (pot metal) is broken and needs replacing, around $30 I believe.
Located in Ruffin, NC
May do a package deal, I also have a 2005 Kraftsman 16x7 trailer.
336-38two-1three8one
Pm or text me and I can send more pics
Will consider full or partial trades!! :zoom:
How about a 99 convertible mustang gt with a rebuilt engine stage 2 ported heads long tube headers catless h pipe alum flywheel trickflow upper elbow and bbk tb
The engine is zero mile as its not assembled I just need to do it kinda lazy right now as its not a priority.
trade
Thanks for the offer but I better stick with slow and easy, speed gets me in trouble! Will consider a more streatable 1st or 3rd gen.
BillM777
