FS: 3rd Gen Lower control arms, Charleston SC, 150
audiness
Senior Member
I have a pair of good used OEM 3rd Gen Lower control arms. I pulled these off a (non-wrecked) junkyard truck, when I thought i botched my lower ball joint install, but ended up not needing them. Asking $150 plus shipping. Located in Charleston, SC . Local pickup welcome and preferred.
I'd be interested for these for my 00 Tacoma but I wouldn't be willing to do $150 + shipping. I'd be more in the $100 shipped range. I bought a set of LCAs, spindles with 10k OEM bearings, stock UCAs and all associated bolts off a member here for under $150. Granted, I met him 2 hours away from me and an hour away from him but I'm just saying $150 + is a bit high. If you wanna do $100 shipped, let me know via PM. I would be using new Energy Suspension bushings in them so bushing condition is irrelevant to me. I prefer for rubber bushings to not be a pivot point and consider the OEM design to be flawed.
Sorry , shipping on these is gonna be a lot, they are heavy . If you pick them up in person , I'll do $100
They're not worth the drive to SC for me. I can get a set from a junkyard in Maryland for less than $75 if I really wanted them. Thanks though.
Not a bad deal IMO. Swapping out complete LCAs with good bushings is a lot easier than dealing with seized cam bolts and replacing the bushings because they needed to be cut out. GLWS
If you intend to keep your sway bar these are not compatible. I believe the sway bar mounts are in different locations.
wwarren702
