FS: 4th Gen 2003 V6 SR5 4x4 - $7,500 (MD)
nasdamus
For Sale is my 2003 v6 SR5 4wd. It just hit 146,000 miles and i'm asking $7,500. That's based on what's available in this area, online and in comparable shape/specs. I'm located in Odenton, Md and am the 2nd owner, purchased in July 2009. Clean title in hand. All maintenance is up to date, well maintained and very clean. I Can take any additional photos. There is rust on the underbody, nothing crazy and normal for a 13 year old vehicle that's survived multiple blizzards! I've used it for camping, OBX, jet ski's and even built a deck hauling all the lumber. It has been my baby.
I recently replaced the worn out driver side leather seat cover, wish i had sooner. The headunit is a Pioneer AVH-P3100DVD (Which is configurable to amber colors so looks stock) and has a CMOS Backup Camera. Did install the PAC adapter to retain steering wheel controls. Also has a heated driver seat. Has been approved for the dash replacement, Annapolis Toyota ordered it but said it was backordered 3 months. I have a ton of extra parts including a Walker catback system that i can reinstall if wanted.
01%20-%20qX0bOCR.jpg~original
FrontLights.jpg~original
03%20-%20zmwMBIX.jpg~original
04%20-%205mJ6JH7.jpg~original
05%20-%20bPHipC6.jpg~original
07%20-%20vt5f654.jpg~original
08%20-%20d65lZRf.jpg~original
09%20-%20PeGq4Q9.jpg~original
a03183ff-a18a-4725-8788-d3df2ced1245.jpg~original
10%20-%20numzHce.jpg~original
Here is just some of the most recent things that have been done:
145,850 - Front End Alignment. Oil Change. Mobil1 and Denso filter
136,750 - Clay Bar and DA machine. Meguiars Ultimate Compound (Yellow pad), Meguiars Ultimate Polish (White Pad), Meguiars Ultimate Wax (Black Pad)
136,500 - Replaced front calipers, rotors and pads. Installed Stop-Tech Stainless Steel brake lines on front and rear calipers. Installed Brake Bleeders all around. Flushed Brake Fluid.
136,175 - KYB GR-2 / Excel-G shocks/spring in front, struts with Moog springs in rear
Energy Suspension rear end-link bushings.
Prothane Greasable Front and Rear sway bar bushings.
Driveline Greased with Mobil1 Synthetic grease
135,950 - Replaced all 6 spark plugs with OEM Denso's
135,400 - Replaced radiator, thermostat, water pump and flushed/filled with Zerex Asian antifreeze
Front and Rear Differential, Transfer Case oil with Mobil1 75w90. Replaced all plugs and washers.
135,200 - 4 New Cooper Discoverer P265/65-17 Tires
129,350 - Replaced rear brake pads and rotors. Replaced Serpentine Belt. Replaced exhaust with Walker QuietFlow SS muffler and tail pipe.
Can you grab a couple more pictures of the undercarriage? By the spare tire, diff, and suspension control arm pickups?
Also, do all 4wd functions work.
Thank you!
Let me know if these work, can get some more tomorrow if there's anything else. All 4wd components work perfectly; there's nothing wrong with this truck at all.
RearBottom.jpg~original
RearExhaust.jpg~original
FrontBottom.jpg~original
Thanks for the quick response. I'm currently working on selling my car, then i get to decide between a 3rd or 4th gen!
I want this ..I want this so bad.....worming and worming my credit union...
Sent from my SM-G900T using Tapatalk
NVBASSJUNKIE
