FS 5th Gen. Full Length Roof Racks by drabbits
Any reason why you didn't close off the back railing? So instead of a V around the fin it would be more like a pointy D?
Strongly recommend putting RTV silicone under the small black spacers and using thread lock on your bolts when you install. I did not and had a bolt come loose and had a small leak at that bolt in a huge storm. I should have put the thread locker on the bolts for sure. Be advised.
Did you put silicone in the bolt holes? Or did thread locker alone do the job?
good to know, thanks for the heads up.
For those that have this rack, is the height 3.5" or 4" or other from the roof of the truck?
Measuring from where the rain gutters are, it's more than 4". But from the center of the 4Runner, it's about 1/2"-5/8". The rack itself is 3.5" tall, which is pretty short for a basket type roof rack.
Closing it off would create faraday cage and disrupt your GPS signal.
I wouldn't put silicone in the bolt holes, I don't see any moisture getting in there actually and I'm sure thread locker is fine. In my case the spot where the bolt backed out was different then all the others, the white piece sticking out of the roof had a rather large gap compared to the others and with the bolt sticking up the water had an easy path in as the black spacer is plastic and I'm sure floats.
Again I should have used thread locker the first time, especially when Toyota chose to use the stronger thread locker to begin with.
I stand by the "better to be safe than sorry" approach.
When installing at the shop, I use a dab of silicone on the bolt threads.
It wouldn't hurt to put a drop of loctite on the bottom of the bolt threads and a dab of silicone in the middle of the bolt.
Shipping to Honolulu, Hawaii
Now shipping to Hawaii!!
$244 to Honolulu, HI
(prices will vary slightly month to month)
Takes about 5 days by ocean and 1-2 days for loading / unloading.
uptheirons;How long from when you ordered the rack until received at MSO? Any plans for a ladder?
I ordered it at the end of August, still haven't got it, but I know Alex is very busy and he is getting them done as soon as he can. i believe he also ran into a issue with his Powder Coater. but I'd rather wait for it and have it done well than try and get him to rush.
I do plan on adding a ladder, but I'm gonna wait. I'll end up getting GOBI ladder when i do decide to get one.
uptheirons;are you going to do the install at the border or bring it back on your roof rack? can't wait to see your pics, planning on a MSO run in spring so want to time the order right.
AndiGarage
