Getadicted
FS: 96 4runner supercharged & locked w/ tons of new oem parts $20k obo, Costa Mesa, C
I'm sure there are things that I'm forgetting but here is the run down of whats been done to the truck:
1996 4runner SR5
New oem toyota parts within 10k miles: lower control arms and bushings, steering rack, lower ball joints, inner and outer tie rods, master cylinder, front brake pads, radiator, upper and lower radiator hoses, heater hoses, oil cooler hose, belts, and fuel filter.
Installed at 204k miles : JDM used motor with 50k miles on it, with new water pump, timing belt, front and rear main seals, and valve cover gaskets, street legal Doug thorley ceramic coated headers, Underdog Racing 7th injector kit including walbro higher flow fuel pump. Rebuilt transmission with Borg warner clutches, new solenoids, and transgo shift kit.
Dual battery setup with bosch agm batteries, tmax parallel battery control system, 00 welding cable to connect batteries with 250 amp fuses, 00 ground cables to frame and #2 cable for motor to body and battery to body grounds, CB radio, pa speaker, custom flip up CB antenna, custom roof rack with 3/8 perforated floor, smittybilt awning, front hi spot led lights, side led lights, rear flood led lights, 4x innovations front and rear steel plate bumpers with rear swing out tire carrier and matched 3/16" mounting plates welded to frame, 9000 lb engo winch in bumper with synthetic line and wireless remotes, flip up front license plate holder, on board air with 6 gallon tank under rear cargo area. Air compressor is inside custom rear over the wheel well box in rear cargo area that is controlled by a switch at the center console and regulated by a pressure switch in the tank. Extended front and rear sway bar links and Sonoran Steel rear sway bar relocation brackets SPC upper control arms with adjustable ball joints, fn wheels 5 star bronze wheels, new goodyear duratrac 265/75r16, Tundra big brake upgrade, ARB diff breather kit, OEM rear e-locker swap, oem manual antenna swap, new oem exterior weatherstrip channels, Subaru RS seat swap, AEM wide band air fuel ratio gauge, auto meter boost gauge, auto meter transmission temperature gauge run in the discharge line, wet okole rear seat cover, spec-d headlight and side light swap. Raptor coated bumpers and rack. Pioneer touch screen stereo with dvd player, Bluetooth, All 4 pioneer door speakers, pioneer 10" shallow sub, and pioneer 1600w mono amp
1996 4runner SR5
