FS: CO 1998 3rd gen SR5 5spd Kings, Bumpers
xpeppyx
1998 4Runner SR5 4WD Originally White/tan interior
5 spd manual transmission
275k miles on body/ ~70k miles on motor
Clean Colorado title
Located in Denver, CO
Coated in Monstaliner Desert Sand bedliner
Frame/body is in good condition for an offroad rig. Rear seats were removed. Could use new front interior door panels and center armrest cover. Center console has aftermarket switch panel, but nothing is hooked up yet. Wiring is in place for the Moromoto lights, but not hooked up. Rear wiper does not work and was partially removed. Rear window does work. A/C works and blows cold. Could probably use a new HID wiring harness as the driver side bulb doesn’t always want to light up. The aftermarket muffler makes a great sound with cracks and pops under deceleration, but is rather loud. Frame is in great shape with just a bit of surface rust. The side mirrors are heated units, but I never got around to wiring them up. The windshield was replaced last summer.
The Whiteline Elastomer LCA bushings and the Total Chaos UCA’s do make a lot more sound than OEM, but should be expected. I have not done any trimming for the 33’s but it will be needed for actual wheeling off road. I’ll include the OEM airbag steering wheel with the sale. It has a top of the line Compustar alarm installed by RSG Offroad. If you want remote start that can be added to the system for $100, I just never got around to it.
I just picked up a new Colorado ZR2 for overlanding and I’m building out a lifted Ford Transit van so I haven’t had time to use or work on this 4runner lately. It’s a very solid vehicle with a lot of maintenance and upgrades done with little mileage put on since.
Asking $9,500/obo
Before you comment on the price being high please read all the maintenance items that have been taken care of recently and consider the newer motor that was swapped in. I'm trying to avoid lowballer offers.
Installed at 269k miles:
JDM 3.4l motor ~55-65k on it
New Koyo Radiator
New OEM fan clutch
New OEM thermostat
New Denso spark plugs
New plug wires
New PCV
New Super Start Platiunum AGM battery
All new hoses
New OEM intake gaskets
New header gaskets
New OEM timing belt
New OEM water pump
New accessory belts
Tundra BBK w/ Powerstop rotors and pads
Stoptech SS front brake lines
Total Chaos Uniball UCA’s
Whiteline LCA bushings
CVJ rebuilt Axles w/orange boots
King OEM Performance EXT 2.5 Coilovers
King OEM Performance 2.5 rear adjustable shocks
Toytec Superflex rear coils
Toytec rear extended SS brake line
Toytec diff drop
Moog 2nd Gen swaybar links front and rear
New OEM lower balljoints
Energy Suspension Sway bar bushings
Energy Suspension Steering rack bushings
New OTE
Lower mileage OEM steering rack
Black Method NV 17x8.5 w/ 285/70-17 Falken Wildpeak A/T3W tires
Addicted Offroad Plate front bumper powdercoated black
Addicted Offroad tube rear bumper powdercoated black
Satoshi Grill
Marlin Crawler HD Clutch kit
Marlin Crawler OEM resurfaced Flywheel
Brand new clutch slave cylinder
Depot headlights with square D2S 3.0 HID retrofit
CBI ditch light brackets w/ Morimoto 4Banger LED light pods
Corbeau Sportline RRS heated seats w/ adapters
Sparco Ring Black leather steering wheel w/ MOMO adapter
Low Range Off-Road shift and transfer case knobs
Blue LED dash lighting
Kenwood DDX9703S 7” stereo with Apple Carplay and Android Auto
Mobil 1 75w-90 Synthetic in diff and transfer cases
Redline MT-90 75w-90 GL -4 synthetic in transmission
Panhard correction kit included, but not welded in
Yakima Core bars and towers included, but not pictured.
Probably more stuff that I can't remember right now.
Interior pictures
Interior pictures:
