FS: Genuine OEM Black SR5 Flare FRONT MUDGUARDS - OR - 200$
UnderFire
Up for sale is a set of the front mudgaurds for the skinny black SR5 flares. This is a USED genuine OEM set.
The driver's side is in good condition, it has one tiny crack that has started, it most likely won't spread unless something hits it or something. other than that it has the normal things you'd expect to see on a 15+ year old mudguard, little scrapes and scuffs here and there, and lots of little dings from rocks.
The passenger's side was damaged in the wreck, but it is all on the inside mounting area, not visible when installed unless you're really looking for it. it has 3 cracks, all of which should be fairly easy to fix using an epoxy or the like. They are all in the area where the mounting portion meets with the actual flap. One is aprrox 3" long, another is 1.5" long and the last is only ~1/3". One small chunk is missing at the end of one of the cracks. It has the same amount of wear from use as the other side.
Comes with all the mounting hardware.
I will gladly send more pictures to any potential buyers so you know what you're going to get before it's on your doorstep.
Asking 200 OBO, don't let the price scare you away, I just don't have a baseline price to go by, feel free to make an offer.
tobasko556
