FS: Hella Optilux Cube 4 LED Driving Lamp Kit - $80 (Los Angeles, CA)
alirawk
Member
Brand new -- In box -- Never used
The Hella Optilux Cube 4 LED Driving Lamp Kit H71020401 is small, durable and uses only 16W of power. The flood beam provides a light angle of 90 degrees. Kit includes 2 LED lamps, 1 relay, 1 fuse, 1 switch, a wiring harness with DT connectors, a mounting hardware and mounting instructions.
PRODUCT FEATURES:
4 High performance LEDs
Small and compact
Low power consumption - 16W per lamp
Creates a homogeneous light pattern
Flood Beam
PRODUCT SPECIFICATIONS:
Part No.: H71020401
Technology: LED
Mounting: Upright
Operating Voltage: 10-30V DC
Power Consumption: 16W per lamp
Lens Material: PC
Housing: Die-cast Aluminum
Bracket: Stainless Steel
Calculated/Raw lumen: 1440 lm
Measured lumen: 850 lm
Dimensions: 3.2”W x 2.9”H x 3.2”D
TerryNap61
