FS: Icon stage 1 lift, DFW, Tx. $1200
yotantexas
Member
This has sold. Money received and shipping out tomorrow
I am changing up my rig a little since its no longer my daily driver and plan to add some more weight with armor and a RTT so this kit needs to go.
This lift was installed in October of 2015 so a little over a year. It has served me very well and the ride is amazing. Has about 20K miles and most of those are highway.
The front coils are standard travel so the stock UCA will work just fine and I had no issues getting my alignment dialed in with stock UCA.
This will fit all 5th gen 4runners, 2007+ FJ cruiser and from what I understand it should fit 4th gen but double check if that is what you have. Front coil part#S11970, rear springs part#52700, rear shock part#56505
I have the original packaging that will go with the set up.
Included: Front coil overs, rear shocks, rear coil springs, spanner wrench, and sway bar mounting hardware.
There are 3 boxes shipping from 76016, please figure what shipping cost is to you. I will be happy to use, FedEx, UPS, or USPS
Box 1 is 40"x3.5"x4" and 10lbs
Box 2 is 22"x14.5"x8.5" and 26lbs
Box 3 is 27"x9.5"x13.5" and 44lbs
If this will work on a 4th gen I will take it. I have tried to figure it out but can't find a definitive answer anywhere. Part numbers for the front coils are different but everything else is the same. Wondering if the front coils are different just because the 5th gens are a little heavier. I have a V8 so the stiffer springs should be ok.
**PRICE DROP $1100**
PM'd
erinobr2000
