FS [PacNorWest]: 1988 4Runner SR5 - $4000 - Seattle, WA
Webbuff
1988 Toyoya 4Runner SR5
- 3.4 (5VZE) V6 swap performed by Toyonlyswaps.com (link to album on Facebook: https://www.facebook.com/media/set/?set=a.10151125801704849.447286.261991549848&type=1)
- 5 Speed Manual Transmission
- 20k on chassis, 90k on 3.4
- Clutch checked at swap and confirmed good and with lots of life on it.
- Timing belt and water pump replaced at time of swap.
- New radiator
- New Catalytic Converter
- 1" 4Krawler (Roger Brown) body lift with Poly bushings.
- Fluids in Rear/Front differential and Transfer case changed withing last 2k with Red Line synthetic (low profile drain plugs installed).
- Fluid for transmission included with vehicle (as well as low profile drain plug).
- FJ 40 soft top with bracket and support bar included (never installed).
- Frame is clean (vehicle was in CA most of its life).
- Body has a couple rust spots that will need addressed, but not bad. (one by rear passenger taillight and the other on the top edge of rear gate.
- Passenger door is dented, but rest of body is in good shape.
- AC does not function (did prior to swap). Cliff at Toyonlyswaps indicated they refilled it but it appears there is a leak in the system.
- Interior is complete, but does have stains (especially the carpet).
- Radio as aftermarket, but is non-functioning.
- Antennae replaced with fixed Crutchfield unit (electric one has a broken mast and will be included with the vehincle.
Its really a great truck, just needs someone who can spend the time on it.
Here are pics:
Odometer as of this weekend.
Interior (from passenger).
Interior (from driver).
Dent in passenger door is from the door being pushed forward to far which also ripped out the limiting strap.
Passenger door (showing dent).
Passenger exterior.
Driver exterior.
Engine bay showing the complete 3.4 swap.
Interested parties can contact me best at my email [email protected].
BillM777
