FS: Peak 7443 Amber LED bulbs, Morimoto LED Load Resistors - $40 - Pittsburgh, PA
97BlackAckCL
Elite Member
Brand New Peak 7443 Amber LED bulbs
BNIB - These sell for $35 new plus shipping. - Selling for $30 shipped
Brand New Morimoto LED Load Resistor
BNIB - These sell for $15 new plus shipping - Will sell for $15 shipped. These are heavy duty and a lot better and produce way less heat than the cheap gold resistor alternatives.
Will sell together for $40 shipped. Items are brand new and never used. Let me know if interested
FYI these will also fit in 7440 (single filament) applications. Since the price was the same I ordered 7443s instead of 7440s for my 3rd-gen in case I ever decided to convert the front signals to a parking/turn signal setup.
So the 7443s will work as park lights on the 7440 socket?
What else would I need to use these LEDs and convert to park/signal lights? Is there a factory 7443 socket that can be used to replace the 7440 socket?
Thanks!
What else would I need to use these LEDs and convert to park/signal lights? Is there a factory 7443 socket that can be used to replace the 7440 socket?!
They will not have dual function (parking and turn) without changing to a 7443 socket.
I don't know of an OEM 7443 socket but these Flosser brand universal sockets https://ebay.us/QajsvG are almost a direct fit, just needs a few seconds of trimming on one of the tabs.
Thanks. Do I need resistors for these LEDs to work? Or are these plug & play after wiring the 7443 socket?
Thank you. I guess I'll go the resistor route as my truck has the side turn signals, making it exceed the maximum number of signal lights indicated on the LED flasher relay.
You have to wire in resistors or get a LED compatible flasher relay otherwise the turn signals will hyper flash.
My personal preference is replacing the flasher as opposed to resistors unless it's a vehicle with no replaceable flasher. How To: Fixing Hyper Flash Turn Signal (Replace Flasher Relay)
I have a set of 7443 relay harnesses that are all prewired and would work with these bulbs. PM Me if you're interested
emilygrace28
