VIN# JTEZT14R668010079
142,614 miles
Very well maintained 2006 4RUNNER 2WD (RWD) V8. I spent almost a year searching for this vehicle and this was the best I found. Florida car its whole life, no rust. Low mileage for its age and confirmed actual mileage; most of the 4Runners I found had been rolled back at some point. Additional photos (can only post 20 on Facebook) available upon request. Carfax report available upon request.
I purchased it in July of 2021 from an elderly man who was anal about having the vehicle be as perfect as possible. Carfax shows a front end accident in 2013, did not see evidence of it being anything more than a minor accident when I had the car inspected prior to purchase. Oil has been changed religiously at 5k mile increments with Mobil 1 synthetic and OEM crush washer. Only Chevron or Shell top tier gas used. I never towed with it. The vehicle has been plasti dipped in a Dark Green color, Jasper Green; Jasper Green Car Kit | Performance Series Plasti Dip
– DipYourCar.com.
The paint on the vehicle had started peeling and I wanted to have it protected so it didn't rust. I have added a few pictures of it before the plastidip. The plastidip can be removed. I will be including extra plasti dip for touch ups. The passenger Rear Door Cladding was damaged by a shopping cart and replaced with a brand new OEM cladding.
The lcd screen has an area that's no longer illuminated by where the date and temperature is. The tint has scratched in some places but is still fully functional. The vehicle is in excellent condition both inside and out and I have maintained and described it to the best of my abilities. The dash looks great with no cracks which is common on these and the GX470's. Vehicle will once in a while throw a P0333 code for knock sensor 2 high bank 2. I reset it with my OBD II scanner and it goes away and rarely comes back.
$10,000 FIRM—Cash only. I invite anyone to have the vehicle looked at as it's in very good to excellent condition. It's located in Wellington, Florida 33449. I am selling since we don't use it enough. Clean title in hand in my name. Comes with original OEM car key/clicker and aftermarket valet style key.
Here is the maintenance from the previous owner up to me:
11/16 89k miles Timing belt, water pump, crank seal front, seals, coolant all belts, Trans fluid, power steering fluid, brake fluid, differential fluid, spark plugs, weatherstrip
(all done at Toyota when the elderly man bought it—see attached)
11/16 Pioneer head unit with backup camera
11/16 Tires & Brake Pads 89k miles
10/17 Magnaflow Exhaust (sounds great)
Front seats redone professionally in leather 3/19
Headlights replaced with BMW style Halo 8/19
Battery 10/20
My maintenance since I purchased the vehicle is as follows:
8/21 114k miles-changed cabin air filter, cleaned engine air filter (reusable K&N filter); Metra volume module which allows you to adjust the volume with controls on the steering wheel to be compatible with the Pioneer head unit; Rostra driver's seat heater-same as OEM in the limited models. New OEM cargo nets and hitch cover.
9/21 NEW Bilstein 4600 front and rear struts and alignment.
11/21 Oil change
1/22 Tighten valve cover gaskets
3/22 Oil change
4/22 Engine and cabin air filter clean k&n
5/22 Oil change
8/22 125671 miles--Oil change, new TPMS OEM DENSO sensors x5 (including spare tire under vehicle and reprogram/reset TPMS), 4x NEW Michelin Defender tires; OEM Pads + rotors rear; OEM Front Pads+rotors+OEM calipers. NSK Wheel bearings + hubs front (purchased from trusted member 05Taco4x4 at Tacomaworld.com forums; Bled brakes and Alignment
11/22 130625-Oil change+align camber
12/22 New OEM Gas cap
2/23 135572 Oil change. Cleaned engine and cabin filters
7/23 Wheel balance
8/30 140,510-Oil change;lean engine and cabin filter
9/23 Remanufactured Alternator OEM Denso
9/23 OEM Window Regulator rear passenger (old regulator pulled off a little of the plastidip)
12/23 All hardware from roof rail replaced
1/24 New Battery
2/24 New Wheel Bearing
Additional pictures/carfax can be provided upon request, I was only able to use 8 here.
142,614 miles
– DipYourCar.com.
Battery 10/20
11/21 Oil change
3/22 Oil change
5/22 Oil change
7/23 Wheel balance
1/24 New Battery
