FTS 5th gen Snorkel Install
Installed!
Installed Pathfinder Outdoors FTS Snorkel:
Thanks Nathan - [MENTION=64685]TOY2G[/MENTION]
FTS 5th Gen Snorkel Kit Toyota 4Runner
Received the snorkel, well packaged, and fast!
Fiberglass Snorkel- Wasn't fond of the fact that it was fiberglass, but willing to take the chance! Well made, and seemed to look as if it would fit well. Not fond of the Snorkel Intake Head. Have a universal, more Safari looking one coming today.
Decided the glossy look of the fiberglass painted was not going to fit my 4Runner look. I painted it the Dupli-color Bumper Trim Flat Black that I have been using for years on my FJ and 4Runner. It will match the rest of the trim perfectly AND when I paint my Fender Trim, it will be a perfect match!
Painted using Duple-Color Bumper Trim:
You can see the difference in finish, as here is the underside
NOTE:
As seen in the below picture, I made my own headless anchor bolts. I simply went to Lowes, obtained the M8 x 1.25 in an 1 1/2" length and cut them carefully with the Dremel, and verify threads before mounting to the Snorkel. I then used loctite-red and used the supplied washer that came with the kit, and added the appropriate lock washer and nut. Made it MUCH easier for placement and install. I would have fought this trying to find the hole through the fender blindly. It also helped to make sure the Snorkel was placed correctly AND that all holes lined up:
Begin the Drilling. I forgot to get a picture of the template laid on fender. It is a tricky template as you simply line it to the top of the Fender trim, and hope for correct placement. Once I felt lucky, I center punched the holes:
Drilled smaller pilot holes before using the Step Bit to achieve a 9/16" hole:
9/16"
At this point, I removed some of the fender liner bolts and peeled down the fender liner to gain access to the inner fender. Only needed to remove the top 3, and one on the upper side towards the passenger compartment. This made it easy to get my arm up.
Removal of airbox should be done as well:
Time to cut a 3 7/8" hole. Rather than buy a new hole saw, I reused the 4 1/8" that I had from installing a snorkel on my FJ. Seemed like it wouldn't make a big difference, as a 4" hole was also suggested from Pathfinder.
NOTE:
It is best to drill using the upper fender angle first, as there is more fender to cut. If you use the lower, more straight up and down angle, it will be much harder to cut when you hit the upper part of the fender. You can see what I mean in pics below.
Continued Below
Test Fit, just hanging on the Anchor studs. Looks good enough to tighten down!
Tightened Down:
I used a silicone tube that was left over from another install, to go over the FTS inlet and the stock airbox connection. I will probably RTV at some point, but the connection is pretty water tight for now. Stock airbox fit over the FTS inlet perfectly. The holes and alignment, much to my surprise, was PERFECT. The inlet from the FTS (seen in above post) was perfectly centered in the opening:
Tightened Down:
FTS Snorkel Head attached. Safari ABS style coming today.
NOTE:
The Plate that attaches to the A Pillar is supplied with silver bolts. I will be painting, as the silver ruins the look. Also note that the plate will need to be built up with double sided tape, as it does NOT lay flat to A Pillar. FTS supplies one layer of double sided tape, AND self tapping screws. The screws could not be used in my case as the plate is about 5/8" from A Pillar. I also used one 6" piece of double sided tape along the snorkel back, from just below where the head attaches, and down the snorkel.
Great install man, thank you for taking the time to do a write-up like this. Looks amazing.
Thank you very much for getting this to me, and for your original write-up!
Thank you for the compliments as well. My FJ and 4Runner would have never been as bad@$$ if it wasn't for you!
Can I share you 4Runner on our Instagram? When we bought ou new TE all I wanted was white, but there were none in the entire PMA we bought from, so I settled.... Now every time I see a sweet white one, I turn green with envy.
Please do! I hear ya, I had to pull strings to get mine. There were only 2 in the surrounding 5 states in white at the time. Thank you!
From those with personal experience, how much does a snorkel affect MPG? My gut instinct would be a guaranteed decrease since you're asking the engine to pull air a greater distance, but to what magnitude? I've asked various people who have them and they've been disappointingly clueless. I've even heard people say, "Well I dunno, it might actually increase MPG cuz of the ram air effect." Sorry, but no.
I'm mainly curious because there's not a dwc within 100 miles of here that would warrant a snorkel. That being said, I can't help but judge people for having them on their daily drivers because they needed it once in their life and now its main purpose is just to show off their off-road cred and decrease mpg. But if it doesn't make that much of a difference then my concerns are baseless and I'm just a hater.
I think the only effect on MPG when you install a snorkel isn't from the snorkel itself, but from dragging your massive balls behind the 4Runner after drilling a 4" hole into the side.
#science #mpglol
nice clean install btw, really like the look of the cut down one with the derpy head.
Also, Pre-cleaners pretty cool, really cut down on dust in super dusty conditions - had one on my troopy back in the day.
I definitely get an MPG boost from my Safari snorkel. About 1.5mpg or better.
Really? Or, sarcasm? Frankly, between the Gobi and sun roof, road noise is nothing I'm concerned about - but a boost in MPG with a accessory that will make all mall crushers jealous - well, I'm in!
With the ARB snorkel prototype i'm running I saw a general increase of about 1.5mpg between 65-70mph. After 70mph the shitty aerodynamics of the entire vehicle work against you anyways.
So not sarcasm. But keep in mind the FTS snorkel =/= the ARB.
[MENTION=64685]TOY2G[/MENTION] What is your current lead time for these units? Ready to order today...
[MENTION=64685]@itsdchz[/MENTION] Such a beautiful rig! Did you notice any change in performance after the install?
Thanks!
