Fuel D630 TACTIC Black Rims for 4th Gen Sport
blkrnnr
Hi all,
http://www.fueloffroad.com/tactic-d630-w-44990.htm
I am looking in to these for replacing stock sport edition wheels of my 2007.
Fuel's website does not list these as compatible with my vehicle.
Comparing these with my other favorite SCS Ray 10, I can't see that big of a difference
Stock vs Ray10: https://www.wheel-size.com/calc/?wh...17X8.5ET-10&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
Stock vs D630 Tactic: https://www.wheel-size.com/calc/?wh...5-17X9ET-12&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
I am going to stick with stock tire size 265/65/17.
One thing about D630 is its bore size is listed as 108 mm.
I am not sure if that will require a hub-centric ring.
Do you all think D630 tactic can safely be installed and would not cause any issues with the suspension down the road (no pun)?
Thank you.
17x9 with -12 offset should be a good fit. May require a little trimming if you’re at stock height. Shouldn’t mess with your suspension at all
erinobr2000
