swampy_swimmer
Did my inspection and mechanic recommended to change those every few years. I dont think my 2002 ever had replaced fuel filter. What do you think?
I left a parking lot, one of the first days of rain in a long time. Stabbed the throttle in first, threw it into second and POW! Truck right on it's face, down to idle rpm's in gear. Push in the clutch and it died.
I thought I snapped a timing belt, or something shat the bed hard. Hard time starting, you get the idea. Changed my fuel filter, truck felt great ever since. Rolls the tires through third gear now in the wet like a champion.
My truck has 214k on it. Each situation will differ, but they CAN make a difference. I always just make sure to buy a quality filter when I do it. No fram crap, I go to Orielly's and get a WIX filter or better.
They go a long time. The tanks at fuel stations these days are pretty clean, and there's filtration on the pumps themselves to keep crap out of the vehicles.
I have one on the shelf to put on mine (I may do it this afternoon) but given the fact that my truck had 210k miles on the original plugs, I'm guessing the filter is original also.
I would say the 60k mile interval mentioned above is probably plenty safe, and the filters aren't expensive so even if it's a little overkill it's not a lot of money over the life of the truck.
Newer vehicles don't even have fuel filters anymore (not sure why).
I was told the main reason cars and trucks don't have a fuel filter on the rail or on the firewall is because due to cost cutting measures. My friend is a bean counter at Ford and that is the reason he gave, though as Jeremy states the refinement and quality of gas has become better since the 3rd gen was introduced so they aren't as necessary today. Ford saves millions so I heard, to keep in the good graces of the shareholders I guess.
Regardless, I still like having one.
I can see the up front savings, but the first time they had to replace a high pressure fuel pump (I'm thinking about a direct injected engine like my BMW has in it), or set of injectors under warranty it would cost ten times as much as they saved. A service advisor would catch hell passing off bad fuel as a cause for warranty denial, and then they'd take a hit in the customer satisfaction rankings. The OEMs get the filters so cheap I'm not sure they'd take the risk of all that if they were still needed.
It would be interesting to know if they're still putting fuel filters on vehicles that are going to South America and Africa. I could see fuel quality there being much more of a concern.
