We had the fuel pump recall replacement performed on our 2018 SR5 about a month ago. Never had any issues with the stalling noted in the recall notice but decided to have it replaced anyway for peace of mind. However, since we got the truck back we have been having issues with the truck taking several seconds (5-8 seconds) to turn over now. Battery is brand new. Most of the time we have to let it turn over once for a second, pause, then turn it over again which still results in a long delay before it starts. When we first noticed this the day after picking it up we took it back to the dealership to have it looked at again and big surprise, they could not find any “codes”. I got some BS line from the tech that the 4Runners do this in hot weather (we live in Las Vegas) and that we would just have to deal with it. We never had this issues in the previous 3 years of ownership with the old fuel pump ( including equally hot summers) and I am furious with the response from Toyota. We even switched from 91 to 87 octane fuel to see if that would help and it did a bit, but the problem remains. Has anyone else had this issue?
they have to drain the fuel, remove the skid plate, drop the tank, replace seals/orings, then raise tank back up, fill it with gasoline. Not sure if you need to prime the system. Check for leaks. Test drive I would assume.
Service advisor had said 3 hours for me. I said um... sure... i'll take the loaner. Took them whole day, I dropped it off at 9am and picked it up 8am next day.
Which toyota dealership did you go to? I live in vegas and haven't done mine yet.
I had exactly the same issue. Pump replaced in February. Last month I noticed hard starting. Then dash lights. Took it back to dealer and yep bad o ring. Which they didn't have. I did get and Avalon v-6 for a few days.Really glad I came here as I just had a similar experience.
I had my fuel pump replaced under recall in December, and just had it fail on me this week. Hard to say if it was related, but should thankfully be covered under the parts warranty.
I got back to the vehicle after a three day backpacking trip and it started rough, had low power, with TRAC Off, CEL, Multi Terrain lights on. The acceleration was a bit rough, but it got to speed and got me home. When I went to try diagnose it the next day, it was in full limp mode. Checked on a few of the obvious things (gas cap, fuses, MAF sensor) before taking to an independent mechanic who identified it as the fuel pump. From there it was off to the dealer where it's now in their hands.
UPDATE: Dealer just called and confirmed it was the o-ring seal that others have mentioned.
Who else is affected by the fuel pump recall but are apprehensive to make appointment because of the O-ring issue? It seems most owners notice the O-ring issue within the first week or so, and another posted in this thread they did not run into the O-ring issue until several months had past. Given the increased importance of the O-ring for the recall, perhaps Toyota will be communicating an important "awareness" to their shops to take note of the O-ring - or even better yet, include a new O-ring with the recall service.
