Fuel Tank Relocation (and new Rear Bumper design)
Put your upper straps in (pro-tip: put the nut on the threaded end in the front mounts BEFORE you snap the other end into the T-slots in the crossmember.)
Keith - do you have PN for upper straps? lower straps easy to find, uppers not so much. i'm finding uppers for side mount tanks, but not this one? Thx
What do you think for the baffle/sump? Shallow tanks begging for it...
I'm going to cut the bottom out of the Toyota one and center it around the Ford tank sump (I think)
Filler neck valve necessary if fuel cap sealed tight?
It's so easy, why not do it? - you could even possibly skip the welding and just drill teh pattern in the tank, sandwich it with the mount ring on the inside, filler neck on the outside...?
Just found my receipt: I ordered them from Bronco Graveyard -
Order Total : $39.85
Order Date : 8/21/2017 8:18:09 PM Eastern
ITEM# DESCRIPTION QTY TOTAL
20355 1973-1979 Ford F Series Tank Straps, Upper Rear 19 Gallon Pair 1973- 1 $25.00
SUB TOTAL: $25.00
TAX: $0.00
SHIPPING: $14.85 UPS - GROUND SERVICE
ORDER TOTAL: $39.85
Might be cheaper somewhere else, but BG had photos, so I knew what I was getting...
My apologies if I missed it earlier, but how far down from the sheet metal floor above does the tank or its support hang? Or, if easier, how much further down from the frame rails? Looks to be just a couple inches...
EDIT/ADD: If this photo above is with the tank in-place, that answers my question!
SUB TOTAL: $25.00
TAX: $0.00
ORDER TOTAL: $39.85
THANK YOU Keith.
during all the clicking, i did find those at Bronco Graveyard and seemed the most likely.
You prob went through same routine... why oh why were these so difficult to confirm? I'd bet that Spectra or Dynawhoever has a PN for them, but just not obvious which ones.
Tony - that's the tank in-place, but keep in mind that without a 1" BL you'll need to clearance the body crossmember above it (there's plenty of material to clearance there) - however, it won't change the relation of the tank to the frame rails, it will sit as shown in either case.
Hope that helps!
Hope that helps!
I should know this answer by now since I have had my parts for this a while, but cyclocross racing takes over all my fall weekends.
With a 2" BL how hard would it be to tuck the tank up farther?
hmm.. - if you flattened the pinch welds on either end and ran totally flat lower straps, you could probably go up another inch with it? it's certainly worth considering in your situation.
May not be worth it looking at the pics. It doesn't look like there is that much hanging down past the frame rails.
Well done. So cool to see all of these small, innovative, parts coming to life that address the flaws of the 4Runner chassis for our applications. Love the simplicity and precise design of your parts.
I gotta say it.... 4th gen next ?!?!?!
Yeah, I'm planning some more 4th gen love. PCK for the 4th gen turned out really well! :)
noticed a few in the thread are from good ole California. Is the f150 tank swap easy to get smog legal?
No smog guy is going to check where your fuel tank is located. As long as it doesn't throw any OBD codes, it shouldn't be an issue. I bet you could even run dual tanks and it wouldn't throw codes with the right venting setup.
I don't think there is any reasonable way to make it truly legal though...
-Charlie
-Charlie
Yeah, I was thinking that as well. With it looking like a factory fuel tank and not something that screams fuel cell I’m sure it’s not to big a deal. Also connected to the factory filler location would make it less
Suspect too.
My first post here, but wanted to get in on the brackets if possible. Joined so I could build my first 4Runner Money pit. 3rd Gen SAS 3/4 Linked. Looks like the fuel tank conversion is a must in the build.
peacefulpiranha
