Fuel Tank Relocation (and new Rear Bumper design)
There's a thread in which one poster put in the Toyota fuel pump and etc. components in the f150 tank. Probably the easier way to get it all to work factory wise. Not that easy to modify the tank though.
Yup, that's one way to do it (this thread here if anyone is looking for it). It's a lot of work though.
When I'm ready to do my tank swap I'll get something figured out.
The problem isn’t the fuel gauge on the vehicle it’s getting this aftermarket module to even communicate with the fuel gauge while receiving a signal from the ford sender. After calling tech support and digging into it a lot more using a multimeter and power probe it turns out that this will not work. If this is really a digital gauge then the Tanks Inc, speedway motors, etc fuel level modules won’t work as they are not designed to do so.
The factory sender is a standard potentiometer. As long as the fuel sender calibrator can act like a potentiometer, it should work. The gauge on the dash may be digitally driven, but that is not what you are interfacing with - there is a signal conditioning circuit in the cluster that takes a standard resistance input then drives the gauge that you aren't going to mess with.
-Charlie
The fuel level calibrators will work for 98 and older trucks (confirm you have a 3 screw gauge) ground style fuel sender (mechanical odo/trip meters)
99 and newer do not use a ground type fuel sender (4 screw gauge). They operate on a 5v refrence on the yellow/red wire and the brown/black wire is signal from sender (regulated 5v through sender). Digital odo/trip meter.
So, at least with the speed way calibrator, (I'm assuming they are all the same) they can NOT see any voltage on its signal inputs or outputs or it will kill the calibrator.
I'll snap a pic of a 99+ level sender and you can clearly see heat build up from current going through it.
Btw the used 99 sender I have reads 140 ohms empty and 8 ohms full, so that also throws a wrench in there lol.
I was (need to mod a new oem sender now) going to use a vdo floatless sender as it's 10 ohm empty 180 ohms full. But seeing that the ohms are bass ackwards that it out. Then I looked a standard potentiometer vdo senders and they all seem to be ground type senders. So time to mod a new oem sender to fit into the floatless vdo 5 hole port. Yay.
Just tested my 2000's sender, just filled it this morning. Key on engine off, 5v+ on yellow/red. 10.2mv+ on brown/black. So yeah, not a normal sender, boo.
Figure out a kit that can use the toyota stuff and sell it. I bet you'd make a good chunk of cash that way. Might be tough to figure out the custom bracketry and such but you'd have a lot of buyers lined up.
I was initially gonna copy that guy exactly and modify the toyota pump and sender and the tank to fit nicely. Then saw the fuel level modules thinking they’d work. Next time I’m doing the extra work and modifying the OEM stuff. Sheet metal welding isn’t awful just go slow
That explains it. It sounds like the dash is expecting a 0-5V signal (basically). The 'error' FSM image above is what you would see when 5V is supplied, but to check without power you need to use resistance.
It would be a fairly simple circuit to translate a standard sender input to a 0-5V signal... but I don't think many people will want a little hand wired breadboard running their fuel gauge.
-Charlie
And the other is that that heat will be carried back over the rear axle and heat the rear tank. Yes it will be highly dissipated while in motion but over a long pull it will affect things. Like excess vapor loss from the rear tank or loading the canister especially on the hot summer asphalt.
As an example, once had a friend cut off the exhaust on a caged truck with no bed, granted he had no down turn, but it heated the fuel cell enough to literally boil the gas out the vent and all over my windshield while climbing the highway up to big bear.
Just something to keep in mind.
THIS^^^
When I initially did this I kept having issues with the tank building pressure and if I was hard on the throttle (more exhaust heat) the tank would build a ton of pressure and leak out. Once I did a down turn to point down and out from under the frame rail, I never had any issues since.
-Charlie
I'm ok with bread boards lol. I'll look into the 0-5v simulator/converter, I found a fuel potentiometer to digital 0-5v converter but it's 110 bucks and didn't dig into it to much.
THIS^^^
So you're saying cut off the exhaust just after the muffler, and add a pipe turning the exhaust toward the frame rail and then down (like how [MENTION=67615]Dirtco[/MENTION] did his exhaust)?
<a data-flickr-embed="true" href="https://www.flickr.com/photos/156493849@N03/49457896852/in/dateposted-public/" title="fullsizeoutput_57f"><img src="https://live.staticflickr.com/65535/49457896852_a586c5bc8e_b.jpg" width="768" height="1024" alt="fullsizeoutput_57f"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Obviously I want to keep my exhaust out of the way from any obstacles.
[MENTION=106706]MN4runnerman[/MENTION] [MENTION=405460]2TH4IST[/MENTION] Could either of you (or anyone else) confirm whether or not the Ford sender hooked directly to the 99+ fuel gauge will read backwards?
It did not read backwards. Fuel gauge didn’t move at all
Can someone give me a quick and dirty summarization of what I’ll need to do with my 1996 I plan to convert to an f150 fuel tank this summer.
I have eimkeith f150 brackets, f150 aux tank with fuel pump from rock auto, fuel tank straps, and I also bought an f150 fuel gauge and sender from auto meter.
I sort of want it to all work like factory and maybe not use the auto meter stuff if I don’t have to if it’s easy enough. But I guess if push came to shove I could redo everything put the pump on a switch and use my auto meter gauge for fuel level and ignore the factory fuel gage in the cluster.
[MENTION=319302]Bad Luck[/MENTION] Here is the link to it. Seems most people use these in their race car data logging systems or digital dashes as they require a 0-5v signal. Being 114 $ plus shipping and tax I don't want to spend that right now lol. We would use the flying lead version.
ICM Fuel Sender
Quick and dirty - want it to operate like stock then you'll need to graft all stock toyota stuff into the tank and mod them accordlingly. A 96 should have basic fuel gauge (grounding style) unlike the 99+ runners. Some say you can bend the ford float to make it read properly but I'm not confirming that as I have a 2000 and can't use the ford sender.
Probably wouldn't be that hard to mount the oem toyota level sender onto the ford fuel pump assembly. And then adjust the float arm to work for the shallow f150 tank. I think the 98 and older runners still have the low fuel sensor so that will need to be adapted into the tank too.
All the info is in this thread and a quick Google search will net the rest of the stuff. Search "3rd gen 4runner f150 fuel tank swap".
Yup that's pretty much what I did too. I ditched the 2nd cat and replaced it with a muffler, then it dumps out under the frame right next to the transfer-case.
I'll try to find a pic to share. Pretty sure I got a pic when it got installed.
[MENTION=28464]eimkeith[/MENTION] he is using a autometer gauge. Looked through his build while I was trying to sort out the 5v fuel sender mumbo jumbo.
The oem sender should be here sat, so with the 3 day weekend I hopefully will have the tank installed finally.
Well got the oem sender modded and swapped in. Had to much other stuff to do so I didn't take any measurements. Just some pics. Tank will go in next weekend as I left some tools at work. One thing I did was flip the float over so it "free spins" on the level arm. It creates more clearance on the top and all I had to do was adjust the roughly 45 degree bend in the arm and make the 90 degree for the float.
REE
