Full frame swap - Advice/input needed
You can always weld a replacement body mount on the older frames. :) It was added for crash safety I belive but could be wrong.. :)
Yes, the b-pillar mount is for crash safety, mostly. The lower bushing even has a bunch of free play in it - it doesn't hold the body until there is like 1" of movement.
Another thing to think about is the 01/02 has the evap system in the back under the truck - the earlier frames may be missing mounts for that.
-Charlie
I thought the rear evap system mounts to the body? You won't have the 2 spare tire brackets that drop the spare tire down about an 1 inch but you can bolt a set on if the nuts are not there. No biggie. The fuel tube is different in the other pre 01 rigs. Frame should work though. Provided those brackets in the middle of the frame are welded on.
I personally, just weld the original frames up. However, I can understand people not wanting to take that project on.. :)
Sent from my SM-A505U using Tapatalk
Oh! It might be to the body. Hard to find pictures...
-Charlie
I have to climb under my 01 to verify. I replaced it several years ago as my was in really rough shape. I am almost certain it's attached to the body. :)
They really made a mess with complexity in the late models.
Maybe they had to meet emissions for the 2001 model year.
Anyway, from my fleet of 5 . As far as I am aware of , those are 2 changes on the frames from 96 to 02 on the 4wd frames. :)
I do know we only have one collision manual for the entire generation. So the chassis are extremely minimal... :)
Guys thanks so much
[MENTION=139000]phattyduck[/MENTION] and [MENTION=164664]brillo_76[/MENTION] thank you both so much for making this a little less daunting!!
seltzernator
