Full XREAS system 4th Gen - Northern VA
HokieRunner
Full XREAS system I removed from my 2005 4Runner.
Key points:
-120k miles on it
-no leaks, was disconnected at the proper junctions to ensure no fluid loss.
-was working fine when it was removed
Located in Northern VA - pickup only. I don't plan on shipping any of this. Offer will be out there for a week at which point I'll be pitching it.
[MENTION=46025]HokieRunner[/MENTION]
Hey guys, these got tossed. Sorry I didn't see your posts before. The rears got cut off so the fronts were the only good ones anyways. I do still have the inline canisters and lines as they're still in the truck.
do you have the air compressor?
I have both the controller canisters still mounted on the truck. I'll be pulling them sometime soon. If you want them I'll box em up and ship them to you for the shipping cost.
They do have 120k on them and I'm not sure if they can be re-used though. Just send me a PM with your info and I'll try to pull them over the next week or two if you decide you want them.
no what i mean is with the limited models that have xreas, some came with load leveler air bags and an air compressor to run them. so i assume you dont have the extra add on to the xreas?
F. Rear air suspension
1. optional on V8 Limited models;
only coupled w/ X-REAS
a. air-filled reinforced rubber springs
b. replace steel coils to support rear vehicle mass
c. superior ride comfort
d. improved performance for towing, occasional heavy
loads
2. automatic load-leveling
a. dynamically adjusts ride height based on height sensors
3. also driver selectable via ctr console switches:
a. raises up to 1½” (40 mm) < 19 mph for clearance,
increased ramp & departure angles
b. lowers ¾” (20 mm) < 7 mph for loading, ingress/egress,
hitching trailer
4. cross-link gate valve opens with transfer case in L4
to increase rear articulation
a. reduces antiroll effect – like dynamic roll-bar on Range
Rover2003 4RUNNER
University of Toyota Jul. 15, 02 p. 16 of 32
ShiftHarbor683
