Fuse box left uncovered when hardwiring something?
You are right, I think it was the 6th gen that I saw, because the tab on top on the 5th geb is on the opposite side as well...
As far as the inner dimension, I could easily change that to match, but getting correct dimensions for the tab on top may be problematic, and that tab has a locating hole in it to grab a tab... The ID is 40mmx103ish.
When I measure from the backside top left corner as origin, it’s 23 mm to the left edge of the hole. The hole is 3 mm wide. From the right edge of the hole to the right edge it’s 15mm. Total 41mm. The tab itself is 15mm.
Then there’s the bottom tab/holes.
From the backside left top corner: 7mm to the first hole edge. Hole is 3mm. From that hole right edge to left edge of next hole is 22mm. Hole is 3mm. Then 6mm to the right edge. Total of 41mm. But the hole placement is not symmetric.
There are some tolerances involved here, it may not make much of a difference, but I could mail you my cover if it would help you get better measurements.
PS, the ID label is 84x34 mm.
If you would like to send me your cover, I can do that, but based on your measurements, I think I was able to get it pretty close. The top offset tab, just appears to be a mirrored version of the other cover I have, but the bottom feet where also inset a little bit.
I have changed the model to reflect these, its up to you if you want me to print this model out and set it to you, or if you would rather send me your cover first.
To add to my confusion, I thought the 2020 4Runner was the 6th gen, I am seeing that it is still a 5th gen and 6th is not out yet even though these forums have a 6th gen section (remember I do not own a 4Runner), but it does appear that the cover I thought was identical to the IS was from a 2020 4Runner. So it is possible that the 2020 4Runner will fit the IS fuse cover.
I am taking this information from post #5 here, that cover looks identical to an IS cover, top tab and all.
2020 fuse box diagrams?
Yes. The 2020 4R is still considered 5th gen. I believe your initial extended fuse cover will fit it’s fuse box.
It looks like your new design will fit the 10-19 model years. I’ll send you a PM.
I ran without a fuse cover for about 2 years, and I'm 6'5" with very long legs. Never had an issue, but always bothered me that it was uncovered. I got a Meso fuse cover and have been very happy having it covered.
Such a great design!
I PMed you the link. For anyone else wanting this file, here is the link. Eventually, I will get it up on Thingiverse.
2010-2019-4Runner-fuse-coverV3.zip - Google Drive
Looks like this file is no longer available. I don't mind paying you for a copy of it or donating to you. I bought the V2 cover for my BRZ off Etsy, and I love it! Now that I have a 3D Printer, I'm dabbling in making my own things...
...but I'm not opposed to buying the 4Runner version off Etsy either. Let me know if you mind sharing the file, or if it is better for me to just purchase it off Etsy.
Cheers!
I actually bought one from this guy
2010-2019 5th Gen Toyota 4runner / Lexus GX460 Extended Fuse - Etsy Canada
fit is excellent and you can reuse the factory cover. plenty of room for add a fuses as well
Yeah, I bought one from [MENTION=611141]ihateu3[/MENTION] from his Etsy Page (HldMyBeerEngineering) for my 2022 Subaru BRZ which is oddly the exact same design as the 4Runner Fuse Box for my 2015. :D So, I know it works well. I was just trying to give him credit and get the design I know I already like.
His V2 reuses the original cover to actually store spare fuses in the cover itself. It's quite ingenious.
He does sell the V1 STL files on his Etsy page, but I really like the V2 better.
V1 for reference:
Cheers!
I don't know why the link stopped working, but here it is again, and its free for members of this forum but I sell it on Etsy because people have asked me to sell it to them. Even though the filename says "V3", it's not actually V3 as in what you are thinking, it was the 3rd revision of V1 because I didn't have a V2 at the time lol. I do not have the V2 uploaded yet, I am not sure if I am going to give that one away or not as of now.
No worries. I will just buy it on Etsy. Having the spare fuses right there is far too convenient. Thanks!
