Fuse tap help... Please!
Spot #1 (which is blank) is +12VDC all times, 10 amps
Spot #2 is +12VDC controlled by headlight switch, 7.5 amps
Spot #3 is +12VDC with ignition, 7.5 amps
Instruction for the add a circuit are pretty obvious and are discussed by others in the last 5 years of posts in this thread, but I thought the above notes and below pic might be of assistance to others looking for a certain fuse output.
FYI
The 5th spot down on the right, that is blank, is 12v switched when the ignition is on
When you use one of the empty spots, do you need to add the second fuse to the add-a-fuse tap? Or can you just use the one for the new accessory?
